Taillights
both inside and out
Taillights
Postby ahale2772 » Mon Nov 28, 2011 6:51 am
I finally got sick and tired of my taillights, they stockers look good, and I like them, but them GAWD DAIMM sockets kept rotting out!!
ive been through three sets of sockets, one that were completly rotted and two that were ok.... but then had rotted off contacts :mad:
anyways, many may hate what these lights now look like, and I'm kinda still warming up to them. i made them quick, whole job was T minus 1hour including wiring 8)
they are simple stop tail turn lights from a tuck supply place, came with the rubber gromet, harness and light for 9 bucks a piece.
wired them up simple, taped up my back up lights (have some mounted on my back rack anyways), going to LED ones soon as I pucker up and buy nice ones
bent up the sheetmetal plates, used the stock taps and nut-certs from the slock lights, the left one came out ok, the right looks like crap. my bed is 100% hacked from the previous owner (i have done zero body work to the truck besides paint) so the lines are all Effed up
anyways... go ahead tell me they look ugly, I dont care because they work 8)
Re: Taillights
Postby ellis93 » Mon Nov 28, 2011 7:08 am
They don't look bad alex. The LEDs will look better ;)
Re: Taillights
Postby ahale2772 » Mon Nov 28, 2011 7:15 am
yeah thats what im thinking, but I didnt want to go through blinker issues right away.
correct me if im wrong... the brake and marker circuts will not need load resistors, but each side of the marker circuts will need one correct?
Re: Taillights
Postby ellis93 » Mon Nov 28, 2011 7:29 am
Only issues that I've had with those type LEDs was they back feed into the park lights when stop lights or blinkers are on. I've over came that with a diode in the park lamp feed. The ones I've used were grote or trucklight brand.
Re: Taillights
Postby ahale2772 » Mon Nov 28, 2011 7:37 am
so what did the backfeeding do? make the markers go dim/bright?
Im thinking they will mess with my flasher if I put them on without load resistors
Re: Taillights
Postby diesel freak01 » Mon Nov 28, 2011 9:38 am
They dont look bad at all. And from what i remember yes you need a load on just the blinkers, IMHO it will look great with LEDs and put some white LED backup lights and it would look great.
1993 d350 ctd drw 2wd auto
diesel freak01
Re: Taillights
Postby ahale2772 » Mon Nov 28, 2011 9:51 am
Thanks! LED's will be next :grin:
Re: Taillights
Postby BobS » Mon Nov 28, 2011 9:58 am
That will work Alex but you now have a new problem. The OEM tailights have built in side marker lights. So what are your intentions for the required rear side marker lights?
BobS
91.5 W250 NV4500 Conversion
89 D350 Stock
BobS
Re: Taillights
Postby ahale2772 » Mon Nov 28, 2011 10:14 am
Yeah, I kinda figured that :| ,if i get stopped, ill use the same lights that I have at the very top of my back rack, maxima makes them they are about 3/4 inch with the rubber grommet, very small but you cant miss them.
same ones I had On my bike
still... Im glad I dont need to deal with those stock sockets
Re: Taillights
Postby ellis93 » Mon Nov 28, 2011 10:51 am
ahale2772 wrote:so what did the backfeeding do? make the markers go dim/bright?
No, I'd mash on the brakes and the park lights would come on. Mine worked without the resistors. I believe that they're built differently(they may have it already) than those chicken crap aftermarket twist ins.
Re: Taillights
Postby PToombs » Mon Nov 28, 2011 6:26 pm
I put the LED lights on and it all worked correctly. No diodes, resisters or anything. I think the fronts draw enough to trip the flasher ok. I'm going to add side marker LEDS too this winter.
Alex, I think your bike needs a tire. :lol:
Re: Taillights
Postby truckwrench1 » Thu Dec 01, 2011 8:15 pm
they make a led specific flasher any aftermarket truck parts house that sells led lights will have them and the grote one was not expensive looks different tall and rectangular but plugs right in
truckwrench1
Re: Taillights
Postby ahale2772 » Fri Dec 02, 2011 4:36 am
Yes, i believe they are electronic flashers, ive got one in it now, so i'll try them without the load resistors first, but I kinda doubt that the front 1157's will be enough load for the whole system.
we will see, im going to buy some led's tonight or tomorrow
Re: Taillights
Postby remi » Sat Dec 03, 2011 11:24 pm
ahale772 howd you run your stack piping?
1992 w250, a518, fuel screw borderline runaway, denny t stage 2 fuel pin, cai,4 turbo back straight pipe to 5inch stack, 4 inch lift, 3 and 1 boost, egt, tranny temp,
remi
Re: Taillights
Postby ahale2772 » Mon Dec 05, 2011 5:21 am
the stack piping is a royal cluster FCUK its 4 inch past the t-case then it goes up and above the frame
essentially i just had to modify the death out of about 6 4inch 90's to get up and over the frame, then up to the bed. (i didnt want to cut a bed crossmember to get it thro)
I have to buy it flowers and dinner to get it out of the truck :lol:
Return to Body
