Rotating mass of the 5.9?
Postby Begle1 » Tue Oct 23, 2007 10:27 pm
Anybody know what the crankshaft, connecting rods and pistons weigh on any old stock 5.9?
Postby 2muchtq » Wed Oct 24, 2007 7:01 pm
not exact... but I'll bet the crank alone will go 300-325
2muchtq
Postby Begle1 » Wed Oct 24, 2007 7:43 pm
That sounds way too much... I thought it was 150-200 for the crank, then 30 each for the connecting rods?
Postby Fnschlaud4620 » Wed Oct 24, 2007 8:37 pm
crank weighs right in around 140lbs
Fnschlaud4620
Postby 2muchtq » Wed Oct 24, 2007 9:09 pm
Must not have eaten my Wheaties.
The ones on my uncles floor feel every bit 300.
2muchtq
Postby KTA » Thu Oct 25, 2007 10:52 am
Actually I think the crank less flywheel is more like 110-120lb. A piston with rings, pin, and snap rings is about 5lb and the rod is about 5 too.
Postby Fnschlaud4620 » Thu Oct 25, 2007 11:53 am
Well then I got screwed on shipping then didn't I :x
Fnschlaud4620
Postby Begle1 » Thu Oct 25, 2007 3:18 pm
A connecting rod is only 5 pounds?
Damn, they sure look more substantial than that on pictures...
Postby KTA » Thu Oct 25, 2007 3:25 pm
I threw one on the scale before I posted that its actually more like 4.7lbs for a rod but it didn't have a bearing in it so I figure 5 be close enough. :roll: On your shipping you probably paid for packaging too.
Postby Fnschlaud4620 » Thu Oct 25, 2007 5:01 pm
The guy I got the a crank from said that he weighed it and it came to 140 AND i paid extra for packaging, OH well some day I'll learn.
Fnschlaud4620
Postby mhuppertz » Mon Nov 12, 2007 7:50 pm
Wonder how a 5.9 would react to knife edging and lightening the rotating assembly and using a Fluid Damper to keep the crank from cracking. I know it would be a little harder to get the dude out of the hole without killing the engine because of the loss of spinning mass, but I bet it would wrap much faster....
mhuppertz
Postby cummins king » Mon Nov 12, 2007 7:52 pm
thats what they did with banks sidwinder race truck, and also thats what audi did with its 24 hour event car
5000rpm no problem, better have a desent set of bearings though
93 4X4 auto
cummins king
Postby mhuppertz » Mon Nov 12, 2007 8:31 pm
cummins king wrote:thats what they did with banks sidwinder race truck, and also thats what audi did with its 24 hour event car
Yea, align honing the mains wouldn't hurt either. I wonder how the stock oil pump holds up under 5k revs?? Enough volume?
mhuppertz
