pulltilbroke wrote:OH yeah and 335$later its got tags with enough tonnage for anything I'm gonna drag around. Kinda nice knowing you 100% legal
Mark Nixon wrote:pulltilbroke wrote:OH yeah and 335$later its got tags with enough tonnage for anything I'm gonna drag around. Kinda nice knowing you 100% legal
Well, sorta', maybe, if you're pulling your own stuff!
Even then, technically, if DOT stops you while towing, you need basic safety equipment like triangles, fire extinguisher, breakaway device, extra fuses, light bulbs of all types for the trailer and truck, ALL axles on the trailer are required to have brakes, ALL lights are required to work, as is the horn, wipers, washers, no cracks or separations (white edges) in the windshield, tires over 3/32" in tread depth (above "check spots"), properly affixed trailer safety chains and probably a shti ton more that I am leaving out.
Basically you must pass the basic safety "sniffer test", at least.
Around here, even the State Patrol can double as DOT and call in the weight van.
So, no, technically you may not be "100%" legal, but you are "closer" with the tonnage.
Paying extra road tax doesn't make you safer or give you a pass with the DOT guys.
pulltilbroke wrote:What are the laws if your just pulling a small utility trailer with no brakes?
Mark Nixon wrote:Looks like your state is missing a potential money grab there.![]()
In these economic times, they'll catch up, trust me.
What I can't believe is how people tend to think these rules don't apply to them because "I'm hauling my own" or "I'm not for hire".
Another good one is "I'm a farmer, those rules for lighting, weight and crap don't apply to me".
Let someone plow into their tractor because they didn't have at least flashers on it at night and see how far that reasoning gets them!
Safety is safety is safety, if it won't stop a trailer or it wanders, or you can't see lighting, it needs to be repaired.
I can't tell you how many times I've run back roads at night and come across some (usually drunk) idiot with no taillights, running 40 mph and I have to try to slow from 60 or so at a moment's notice.
