injection pump leak
injection pump leak
Postby Hansen01 » Wed Dec 07, 2011 9:49 pm
well i put all new o rings in my vacuum pump and replaced the powersteering pump tonight, good news is there no leaks there anymore :D , bad news is that my injection pump it leaking at the front underneith the big spring that all the throttle cables control, i have a picture on my fone but cant get my computer to cooperate with me to upload it, any help on why its leaking would be apretiated, it is not leaking out of the pump top, but out of whatever is underneith the spring :x
Under construction...
Hansen01
Re: injection pump leak
Postby cmann250 » Thu Dec 08, 2011 5:27 am
The throttle shaft has an O-ring on it. A reaseal kit is like $20 from a Cummins dealer ant it'll fix your next leak too ;) It's pretty straight forward
Postby Hansen01 » Thu Dec 08, 2011 4:51 pm
alright does it jus pull off of there or is there some majic behind it, anything i should watch for?
the truck jus cant go a day without marking its territory :roll:
Hansen01
Postby cmann250 » Thu Dec 08, 2011 5:36 pm
I take it you haven't done a 366 spring? Take the pump top off then, IIRC, the govenor spring is hooked on one end to this throttle shaft by way of a swivel and the other end is hooked to the tophat/washer assembly. Once the top is off, you can push the throttle shaft through
Mine makes it VERY obvious where it's parked. LP, IP, oil, trans fluid :lol: I fixed them all except the oil leak. It's just sweating horsepower 8)
Postby Hansen01 » Thu Dec 08, 2011 7:58 pm
haha yes, diesels to exspensive to sweat off tho :D and no i havnt done that, always been to chicken to do it,lol
and you have to take the top off to fix my leak? hmmf :x
Hansen01
Postby cmann250 » Fri Dec 09, 2011 5:41 am
I think we're thinking of the same thing :lol: I'm not smart enough to be able to post pics either :lol: If you're already in there, may as well do the 366 spring, it feels sooo much faster with the 366 spring, which is only another $20.
Cummins doesn't nickel and dime you to death, they $20 and $50 you to death :lol:
Postby Hansen01 » Fri Dec 09, 2011 6:10 am
lately its been 50 and $100 me to death,lol well i try again tonight to get the picture up, i think yur on the right piece to 8)
Hansen01
Postby Mark Nixon » Fri Dec 09, 2011 8:01 am
Personally, I'd just pull the pump and re-seal the whole thing.
The chances of losing parts go up when you try to do it in place.
Postby Hansen01 » Fri Dec 09, 2011 7:40 pm
hmm, alright, thanks guys, il call in reinforcements just in case lol :D
Hansen01
Postby cmann250 » Sat Dec 10, 2011 5:39 am
I left it on the truck just because i didn't have the means to pull the IP off. Good luck to you 8)
