04 exhaust manifold
04 exhaust manifold
Postby remi » Wed Dec 14, 2011 9:28 pm
will an 04 exhaust manifaold fit on my truck in the sig?
1992 w250, a518, fuel screw borderline runaway, denny t stage 2 fuel pin, cai,4 turbo back straight pipe to 5inch stack, 4 inch lift, 3 and 1 boost, egt, tranny temp,
remi
Re: 04 exhaust manifold
Postby remi » Wed Dec 14, 2011 9:33 pm
o will added the o4 turbo help any ether?
remi
Postby Tacoclaw » Wed Dec 14, 2011 9:47 pm
The ports on the 04 will be round holes, our's are a rectangle with rounded corners. Not life ending, but it won't be an exact match. A few hours with a die grinder will match them up pretty good, just have an manifold gasket on you to mark what you need to reshape them to.
Now, the kicker is does the 04 manifold have the turbo mounted in the middle at an angle, like ours, or does it have it mounted towards the rear and mounted vertically? If it's the same as ours, then the port mismatch should be your only concern.
Postby remi » Wed Dec 14, 2011 9:50 pm
would it help any performance wise
remi
Postby remi » Wed Dec 14, 2011 9:55 pm
or would an 01 manifold and turbo work a little better??
remi
Postby oldestof11 » Thu Dec 15, 2011 5:05 am
01 would be better than the 04. It puts it in the same location as ours.
IMHO, no it is not a upgraded part.
Postby rattlebox93 » Thu Dec 15, 2011 11:10 pm
Do a industrial manifold i absoutly love mine send me a text and i can send u some pics 618 920 2827
rattlebox93
