Water/meth question
Water/meth question
Postby THE TANK1 » Tue Oct 23, 2007 5:04 pm
Has anyone ever tried sparying water before the turbo? Would running grain alcohol in with the water help? thanks
1990 dodge 550 monkey pump, stacks, southbend DD,
THE TANK1
Postby Begle1 » Tue Oct 23, 2007 7:21 pm
The logic I've heard on why NOT to do that is liquid water droplets hitting blades spinning at 100,000 RPM. Which makes sense to me.
Nitrous and propane are both fine if injected before the turbo, though...
Postby Cschafer » Wed Oct 24, 2007 12:55 pm
I've seen it alot on turboed and belt driven turbo gassers. Alot eisier since you just use boost pressure to push in the mix. I havent heard of any problems from it.
91 w250 wrecker
Cschafer
Postby DTanklage » Wed Oct 24, 2007 4:08 pm
i built a water system for turbo gasser 25 yrs ago
hooked it up just like that (squirtin right into the turbo)
it worked ok since at the time we didnt have the money to do it right
was just a windshield washer set up
but - with todays high pressure pumps, check valves, solenoid valves, etc, there is no reason to inject it there. its kinda like the nitrous senario - what do you want to cool? the hardware or the charge?
i want to cool the charge
DTanklage
Postby THE TANK1 » Wed Oct 24, 2007 4:18 pm
Thanks, what about putting in grain alcohol in with the water. I need to cool it down like 200 degrees?
THE TANK1
Postby THE TANK1 » Wed Oct 24, 2007 4:19 pm
THE TANK1
Postby DTanklage » Wed Oct 24, 2007 6:27 pm
alcohol makes power
power makes heat
DTanklage
Postby Begle1 » Fri Oct 26, 2007 6:11 pm
DTanklage wrote:alcohol makes power
power makes heat
Theoretically... If your timing is really retarded, then a little bit of alcohol could help the Diesel burn better and reduce afterburning...
I think those conditions would be pretty limited, though.
Water alone reduces temperatures a bunch, though.
Postby DTanklage » Fri Oct 26, 2007 8:53 pm
have not installed mine yet - still screwing around with the turbo and tuning (and the ex and the brake) (nightmare)
but from what i have heard... 50% methynol (if it is fresh, like race track fresh) will cancel out all the cooling properties of the water but straight water, once it is properly tuned, will cool exactly the amount you are looking for (200°)
i also heard that a 400 hp (first gen piston) motor requires LOTS of water to get the job done but they cant handle very much water under low boost conditions
will find out if all that is true one of these dayz...
DTanklage
