Shift Kit
Re: Shift Kit
Postby CaseyF » Tue Mar 22, 2011 11:05 pm
What's a reversed kit?
1992 W350 flat bed. GlowShift Gauges, 3.54 gear, Full Power Screw bottomed, DennyT Pump Top Delete, 366 GSK, Custom CAI, Pro Comp fuel pump, DE 4'' Exhaust, 14cm Exhaust Housing, Getrag.
CaseyF
Re: Shift Kit
Postby jughead » Wed Mar 23, 2011 2:59 am
reverse pattern is just like it says. d is low, 2 is 2nd, 1st is high gear. as far as i know no one sells the kit for the od trans. they only sell the complete valve body. the 3 speed takes a special steel plate which i dont know if it is still available but if it is the reverse pattern 3 spd. is easy to do.
jughead
Re: Shift Kit
Postby CaseyF » Wed Mar 23, 2011 8:01 am
Oh, ok I see now.
CaseyF
Re: Shift Kit
Postby jughead » Sat Mar 26, 2011 3:37 am
well the old man bit the bullet and bought the reverse manual for the 518. just need to check the 2 shim sizes before bolting od to trans case. dont know how long before i get it in the truck. this project has been going on all winter. old and slow and just a whole lot lazy.
jughead
Re: Shift Kit
Postby 91bluecummins » Sat Mar 26, 2011 1:52 pm
how much was it and what shims and were did you get it
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Re: Shift Kit
Postby jughead » Sun Mar 27, 2011 4:35 am
bought it from A an A trans. 600 plus a special low and reverse servo. the shims need to be checked when building the trans. the od clutch piston shim and the intermediate shaft clearance shim. they are critical to a proper 3rd to od and od to 3rd shift. if not correct one can get a flare up or a bind up when it shifts. needless to say i had all the shims but the 2 i needed so will have to order monday.
jughead
Re: Shift Kit
Postby jughead » Wed Mar 30, 2011 5:12 am
well this old man hit another snag. seems the dealer in chattanooga cant find the part number for the intermediate shaft selective spacer. it has to be installed with snap ring pliers. sent me the pics he has and it isnt any wonder he cant find it. it is not in his parts book. there are only 4 sizes and i need the thickest one. any help out there. the thing is about the size of a half dollar if anyone remembers those things.
jughead
Re: Shift Kit
Postby jughead » Thu Mar 31, 2011 9:46 am
well i found the spacers. one can try "what it takes trans parts". i opened an account today.
jughead
Re: Shift Kit
Postby Beattyr87 » Thu Mar 31, 2011 10:39 pm
So anything for a 727 will work for a 518 I want to put a quarter stick shifter from my nova into my truck the nova has a 727 tranny in it will it hook right up.
Beattyr87
Re: Shift Kit
Postby jughead » Fri Apr 01, 2011 3:08 am
most of the parts in the front half of the 518 and 727 will inter-change BUT not all. valvebody of course is diff. low and reverse drum and band is diff in the diesel. may be some more small parts but cant remember. it has been over 10 years since this old man did much mixing and matching on these things.
jughead
Re: Shift Kit
Postby Beattyr87 » Fri Apr 01, 2011 6:34 am
More specifically I'm interested in the shifters will they interchange or will I need a plate specific to the 518
Beattyr87
Re: Shift Kit
Postby jughead » Fri Apr 01, 2011 3:19 pm
if it bolts to the case it will need a different plate. extension housing is diff.
jughead
Re: Shift Kit
Postby jughead » Sun Apr 10, 2011 5:10 am
trans is done just got to wait on a buddy to help get the old one out and the od bolted up. old man cant handle this heavy stuff any more. once he gets that done i can modify cross member as needed and get the driveshaft cut and balanced. with 3.21 gear it ought to be a nice all round street machine.
jughead
Re: Shift Kit
Postby jughead » Mon Dec 19, 2011 4:04 am
finally got the trans in. it doesnt shift any harder than the 3 speed but is a little harsh for street. with the diesel though unless i am showing out never use anything but 3rd and 4th. 4th shift is absolutely perfect for this old man though. made my 82 come ALIVE at highway speeds. :D
jughead
Re: Shift Kit
Postby jughead » Sun Jul 06, 2014 4:55 am
been a while but trans still working fine. would love to have a kit to do reverse pattern manual valvebody for the od trans. if anyone knows of one would u please let me know
jughead
Return to Transmission
