ellis93 wrote:.. things first
1 how are you measuring the voltage
AND what are you voltage readings USING a real hand held voltmeter at the battery terminals?
What voltage reading is at the battery terminals BEFORE you start it?
What voltage reading is at the battery WHILE it is charging?
What voltage reading is at the battery when it quits charging?
What voltage reading is at the battery after it quits charging and you turn on the headlights and put the heater on high?
The charging system is designed to replace the power consumed from the battery and does not provide additional charging when there is no load placed on the electrical system.
ALSO, does your truck have a crank shaft position sensor? Is it gapped correctly and are the wires and connections intact?
