INJECTOR CHART
INJECTOR CHART
Postby DTanklage » Sat Oct 20, 2007 8:08 am
stock 1st gen inj - 6x.009" = .000380" total cross sectional area
non ic inj - 4x.013 = .000531 ( larger than ic inj)
2nd gen inj - these vary depending on model
160 hp- 5x .008
175 hp 5x .009
180 hp 5x.009
215 hp - 5x.010 (0.000393)
185's = smaller than stock
190's = smaller than stock
230's = ?
300's = 4x.014
ddp stg III = 50 LPM (liter per minute) 5 hole extrude hone inj
330's - 5x.011 = .000474 (20% larger than stock)
2nd gen 370's - 5x.012 = .000565 (48% larger than stock)
ddp stg IV = 55 LPM (only 10% larger than stg III's) 5 holes <.013
ddp stg 4plus = approx 65 lpm
ddp comp = 73+ lpm
pods - 4x.015 = .000707 (% larger than stock)
2nd gen 435's - 5x014 = .000769 (twice as large as stock)
custom injectors -
6x13 = .000795
5x15 = .000882
6x14 = .000923
5x16 = .001005
6x15 = .001059
5x17 = .001134 (300% larger than stock)
6x16 = .001206
5x18 = .001272
6x17 = .001360
5x19 = .001416
6x18 = .001526 (400% larger than stock)
5x20 = .001570
6x20 = .001884 (500% larger than stock)
5x22 = .001900
5x24 = .002261
6x22 = .002280 (600% larger than stock)
competition p-7100 injector 5x25 = .002459 (freg↓n huge)
ind inj super dragon flows (10 hole) - 5x10.5 + 5x18
please post the sizes for the tips that are in question (if you know them)
thanks
DTanklage
Postby CumminsPride » Sat Oct 20, 2007 9:41 am
New Era 435's= 5x.014
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby ford69557ci » Mon Oct 29, 2007 10:59 am
Im goin to have some 6x20's done how much over stock is that?
ford69557ci
Postby DTanklage » Mon Oct 29, 2007 11:41 am
look at the chart aaron -
they are 5 times as big as stock
lol
DTanklage
Postby DTanklage » Mon Oct 29, 2007 11:43 am
ps - that should be good for about 800 hp if your unit is big enough to burn it all
forgot to ask you what size jets you are running with the stg 4's???
DTanklage
Postby ford69557ci » Mon Oct 29, 2007 12:42 pm
i think im gonna need biger turbo steup than the s300 s400 setup i had planed on. maybe a 5k aurora and a s500 series
ford69557ci
Postby cummins king » Sat Nov 03, 2007 6:53 pm
is there a calculation to figuar out the total cross sectional area of an injector, with the admount of holes and size o holes
93 4X4 auto
cummins king
Postby gman07 » Sat Nov 03, 2007 7:40 pm
A= pi r squared
Area of one hole * number of holes = total area
3.14*((1/2 diameter)^2) * number of holes
For example, stock 6x.009:
3.14*((0.5*.009)(0.5*.009)) * 6
= 0.000382
Or if you wanted to be more accurate you could use 3.14159265358979323846264338327950288419... for pi. :P
gman07
Postby DTanklage » Mon Nov 05, 2007 12:21 pm
who makes 8 hole injectors?
don
DTanklage
Postby DTanklage » Mon Nov 05, 2007 12:39 pm
gman07 wrote:
A= pi r squared
= 0.000382
when i figure them i find the Rsquared part first, then multiply by 3.14159, then multiply by the number of holes
iow for 8 by 11 ▬ 11/2=.0055; .0055x.0055=.0000302; .0000302 x 3.14159 = .0000948; times # of holes 8 = .000758" (i drop the 4 and only go out 6 places)
don
DTanklage
Postby cummins king » Mon Nov 05, 2007 3:54 pm
edge products does, but they dont make them for our year, unless you get them costom and they smoke like crasy so i was told
93 4X4 auto
cummins king
Postby ford69557ci » Mon Nov 05, 2007 4:55 pm
seems like 6 hole seem to run the cleanest on 12v
ford69557ci
Postby BC847 » Mon Nov 05, 2007 5:09 pm
FYI: ref ~ The DDP4 1st Gen injectors.
I talked with the fellas at DDP today regarding the DDP4s for the 1st gens and had no luck in getting the actual orifice size. Also, the older versions run five orifices where as the newer now run four orifices.
Postby DTanklage » Mon Nov 05, 2007 6:07 pm
they are small
much smaller than 014
all i know is that they flow 55 liters per minute compared to the stg III's 50 lpm - and both are smaller than pods
with the ve being such a small pump i dont know why they didnt take em out a ways further and make them bigger than pods?
its not like we can make the pump push a bunch of fuel to make hp
we cant
have to do it with big injectors
DTanklage
Postby ford69557ci » Mon Nov 05, 2007 7:36 pm
like some 6x22 or 24 lol
ford69557ci
