crossover tube for he351 on non i/ c
Postby fatstack » Sat Jan 14, 2012 8:13 pm
Does anyone make a crossover tube to bolt a he351 on a non i/c ? How hard would it b to make ? Thanks
89 d250 getrag ripper, pump maxed,timed to the head,pull cable shutoff, 354 spring, straight pipe, 4:10 gears, in the shop: he351cw and 3:07 gears
90 w350 nv4500,ic motor, stock, 5" stack w a western hauler on back
fatstack
Re: crossover tube for he351 on non i/ c
Postby huntinguy » Sat Jan 14, 2012 8:51 pm
I made one. It's not to bad if you're a good welder.
89 non-I/C W-250, flatbed. 4" turbo back. Ground fuel pin, AFC tuning.
huntinguy
Postby fatstack » Sun Jan 15, 2012 8:22 am
Hell yeah. Where would one source the plate that bolts to opposite end? Or can that b fabbed as well?
fatstack
Postby huntinguy » Sun Jan 15, 2012 1:47 pm
I made that myself too
huntinguy
Postby fatstack » Sun Jan 15, 2012 2:08 pm
10 4. What all bends did it take ? Can i mig weld it?
fatstack
Postby Hansen01 » Sun Jan 15, 2012 2:10 pm
not to highjack, but how do you like the 351?
Under construction...
Hansen01
Postby huntinguy » Sun Jan 15, 2012 4:37 pm
Yea it works great. My main thread is on Cummins forum. Search for "He351vgt specs"
huntinguy
Postby huntinguy » Sun Jan 15, 2012 4:39 pm
fatstack wrote:10 4. What all bends did it take ? Can i mig weld it?
Probably two 30* and a 90* not really sure I made it out of old exhaust pipe.
huntinguy
Postby fatstack » Tue Jan 17, 2012 2:39 am
Many thanks. This seems to b an uncommon piece but that clears it up for me. :bom:
fatstack
Postby Tacoclaw » Tue Jan 17, 2012 7:44 am
If you can't weld, or your welding skills totally suck, you can make something similar out of silicone connectors. For my setup I needed a 90* and 2 45*s, but if you're keeping the grids you'd need to swap the last 45* for a 90*.
These first pics had normal rubber connectors, which just popped, but I got some silicone ones from siliconeintakes.com that have worked out fine at 50psi.
viewtopic.php?f=4&t=5512&start=0
Postby fatstack » Thu Jan 19, 2012 2:46 am
Looks like they've got all the parts i need. That site could b addicting though lol
fatstack
