Injector size for 14mm head
Postby ford69557ci » Mon Oct 29, 2007 12:14 am
This is for KTA. What size injectors do you run? I was thinkin on havin some 6x20's done. What do ya think?[/code][/url]
ford69557ci
Postby DTanklage » Mon Oct 29, 2007 9:48 am
i hope it doesnt get cold where you live...
DTanklage
Postby ford69557ci » Mon Oct 29, 2007 10:31 am
not really i park in the garage anyway so it doesnt mater much on temps
ford69557ci
Postby THE TANK1 » Mon Oct 29, 2007 4:04 pm
thats why they make either :twisted:
1990 dodge 550 monkey pump, stacks, southbend DD,
THE TANK1
Postby ford69557ci » Mon Oct 29, 2007 5:20 pm
i work on heavy equipment so i have plenty of that layin around
ford69557ci
Postby DTanklage » Mon Oct 29, 2007 6:04 pm
huh?
DTanklage
Postby ford69557ci » Mon Oct 29, 2007 6:12 pm
ether i buy it by the case :twisted:
ford69557ci
Postby DTanklage » Mon Oct 29, 2007 7:32 pm
ohhh, starting fluid
i dont use that stuff
if anything i build fails to start it means something is wrong and i need to trouble shoot - not shoot it with either!
lol
you guys are nutz
DTanklage
Postby ford69557ci » Tue Oct 30, 2007 9:54 am
if you work on old ass equipment then ether is your best friend and so r 24 volt jump boxes amazing how fast 24v will make a 12v system start.
ford69557ci
Postby KTA » Tue Oct 30, 2007 10:27 am
With enough nos they will probably be fine, fuel only power will be down. :roll:
Postby DTanklage » Tue Oct 30, 2007 11:15 am
i dont know about that kta
josh used 6x18's to match billy bobs numbers and he is only using a 62mm wheel compared to bobs 71!
DTanklage
Postby ford69557ci » Tue Oct 30, 2007 2:11 pm
i plan on a decent set of twins or if decide to just pull one large single
ford69557ci
Postby cummins king » Tue Oct 30, 2007 9:02 pm
talking about either we have a loader that we'ed have to either all summer :lol: long to get that thing start(don't even start with the winter), and it wasn't a quick spray we had to empty the can befor it would start, then we desided it was a good idea that we get a new motor lol
93 4X4 auto
cummins king
Postby cummins king » Tue Oct 30, 2007 9:08 pm
so KTA what size injecters are you running.
93 4X4 auto
cummins king
Postby KTA » Wed Oct 31, 2007 7:04 am
I have run 5x.014, 6X.016, 6x.018, and 5X.020. Yall are welcome to get a set of each made and try them out to find which is the best for your setup, thats how I did it. The ones that make the most power for me are not the biggest ones, but on the bottle they probably would be.
