peobryant wrote:I'm a fan of the Super HX40. It has a 4" outlet you you will need to either buy or make a 4" downpipe (I know the HX35 has a 3" outlet, I'm not sure about the HE35CW.)
Hansen01 wrote:peobryant wrote:I'm a fan of the Super HX40. It has a 4" outlet you you will need to either buy or make a 4" downpipe (I know the HX35 has a 3" outlet, I'm not sure about the HE35CW.)
351 also has a 4in outlet
1990BamaCummins wrote:Im running a 3" cross-over, 4" down-pipe, 100 hp injectors, pump tweaks, BD fuel pin and gov spring, DNR cold air intake, M&H dynamic timing advance spacer etc other odds and ends......
Hansen01 wrote:All just depends on how far you wanna turn your pump up i guess
