Fuel pin usefulness.
Re: Fuel pin usefulness.
Postby huntinguy » Mon Feb 14, 2011 9:57 pm
here's mine.
Just for kicks. :D
89 non-I/C W-250, flatbed. 4" turbo back. Ground fuel pin, AFC tuning.
huntinguy
Postby IrishChamp » Mon Feb 14, 2011 10:56 pm
Excellent
1993 W250, 115k miles, pump turned up, M&H Timing Spacer, built a518 w/ steel stator spec rite, he351ve, 16" steel wheels, 255/85r16 BFG Km2's
IrishChamp
Postby lectro_static » Wed Feb 16, 2011 9:29 am
Not trying to talk you into or out of anything, I have an m3 pin and a 5spd with stock injectors and never had a leaking problem. I went with the aftermarket pin for two reasons, first being if I didnt like it for some reason I can drop my stock pin back in and second being the ground pins looked and felt weak. I have not heard of one breaking but that would be just my luck.
weeping head gasket
4" straight pipe
M&H M3 fuel pin
M&H Dynamic Timing Advance
366 spring
Auto Meter EGT and Boost
lectro_static
Postby dpuckett » Wed Feb 16, 2011 1:10 pm
I ground my stock pin on a belt sander, then smoothed it out on a buffing wheel for a nice smooth finish. I dotn remember how much boost I gained- that was 2 years and a pickup ago.
DP
Postby huntinguy » Wed Feb 16, 2011 3:56 pm
lectro_static wrote:Not trying to talk you into or out of anything, I have an m3 pin and a 5spd with stock injectors and never had a leaking problem. I went with the aftermarket pin for two reasons, first being if I didnt like it for some reason I can drop my stock pin back in and second being the ground pins looked and felt weak. I have not heard of one breaking but that would be just my luck.
Remember, The fuel pin has two sides. :lol:
huntinguy
Postby ellis93 » Wed Feb 16, 2011 4:04 pm
Funny, I thought it was cylindrical ;-)
Postby huntinguy » Wed Feb 16, 2011 4:08 pm
ellis93 wrote:Funny, I thought it was cylindrical ;-)
Ok, four sides. :lol: But with it ground you could only use two. I think. :roll:
huntinguy
Postby IrishChamp » Wed Feb 16, 2011 4:37 pm
Which side do people usually grind? How much difference does just flipping the pin to side two make? I would think that grinding side two makes the most sense and allows the deepest cut.
IrishChamp
Postby Richie O » Wed Feb 16, 2011 5:05 pm
You have to grind the deep side. If you grind the shallow side you will grind it in half before you get what the deep side uncut already offers.
Postby IrishChamp » Tue Mar 08, 2011 3:31 pm
I did a little bit of grinding this morning. It made a subtle but nice difference. I also installed a 3200 spring a couple days ago, turned my pump a a turn or two, I'm not sure exactly, I jacket it out to reinstall pump top and then slowly went back in till it started and ran nice.
Installed a boost and EGT gauge as well, I'm making about 24 or 25 lbs of boost and my EGT's don't climb over 1200.
I really want to get a tach now! Previously my truck would do 29 in 1st now it screams past 35 quickly approaching 40 and still pulling hard, I backed off when it hit 37 or 38. In 2nd at 55 or so it's still pulling and 3rd at 75-80 it's got plenty more.
This is all with my rebuilt transmission and steel stator spec rite converter.
With this converter and a stock truck it was sluggish down low, but idled great and didn't pull at idle. Mid throttle was much improved driving around town.
With the power turned up a tad the converter is really happy. Bottom end is great even with the 21 exhaust housing, it pulls through all gears, it gets into the power band well but it doesn't just rev up instantly like before which I like, the connection between the engine and wheels feels much more "connected".
IrishChamp
Postby IrishChamp » Wed Mar 09, 2011 1:36 pm
Here are a couple pictures, 1st one is what I did yesterday, then I worked it again today.
IrishChamp
Postby IrishChamp » Wed Mar 09, 2011 10:04 pm
And a little more work, I noticed that the new wear track was going past the low point back up the slope towards the body so I extended the low point to the body of the cone rather than having it blend into the natural ramp into the body of the cone. I think I'm done!
IrishChamp
Postby IrishChamp » Fri Mar 11, 2011 12:04 am
I picked up 1 or two lbs of boost with the last grind and a little starwheel tweak.
IrishChamp
Home Ground
Postby Horicon93 » Wed Jan 25, 2012 8:47 pm
What kind of performance differences (compared to stock) have you noticed since grinding your pin?
'93 Extended Cab, DRW, 2WD, Auto, 4 1/2" stacks, Bone Stock
Horicon93
Postby artieb » Wed Sep 18, 2013 1:15 pm
Hi, I have been doing a lot of homework on fuel pins. I think a M1 would be the best for my style of driving, and would be the most likely to be ground further, if needed, for more aggressive feuling. I don't know makes them. I get fabulous mileage now, and will be installing a 3200 spring soon. Other than that, the IP is untouched on my 92 CTD, with a PS inner cooler.
I have a HX35 that is in the works, also.
Anybody have any input? And where I can get one? Thanks, Artie
93 CC CTD auto 4x4 plow truck, 01 Fummins with 92 CTD, ZF-6 in northern Indiana AND a VE pumped 1.6 TD 1986 Samurai
artieb
