tanks psycho fuel system
Postby DTanklage » Mon Oct 29, 2007 11:38 am
dunno...
i thought about that because the fuel cell i am gonna use for my water system doesnt have any fittings in the bottom of it either...
even if you do get a sump in the stock tank the problem still remains that the outlet will be at the lowest point of the truck. for what you are doing you would be better off with a tank high up in the bed gravity feeding the pumps thru some fat lines
DTanklage
Postby ford69557ci » Mon Oct 29, 2007 5:13 pm
guess i need to find a 30 gal fuel cell
ford69557ci
Postby DTanklage » Mon Oct 29, 2007 7:33 pm
or a 60 gal alum fuel tank...
thats what i am using
and lovin it!
DTanklage
Postby bgilbert » Thu Nov 01, 2007 7:16 pm
ford69557ci wrote:how would you go about runnin a bottom sump on the factory plastic tank??
-12jic/an (3/4") bulkhead fitting in the bottom of the tank like mine:).
Bill Gilbert
Postby DTanklage » Fri Nov 02, 2007 12:09 am
thats not a sump bob
thats a fitting screwed into the bottom of a fuel tank
yes, there is a difference...
DTanklage
Postby cummins king » Fri Nov 02, 2007 7:11 pm
ebay thats the chepest way to find a good 30 to 60 galon tank
93 4X4 auto
cummins king
