Weird starter problem
Postby cmann250 » Sat Dec 10, 2011 3:07 pm
I buttoned up the truck today after the 47RH debacle i put myself into. When i went to start it, i turned the key to ON and i got a whining sound followed by a bunch of heavy metallic clicking/popping. I turn the key to START and i get nothing but a couple slow clicks.
The catch: i'm using a 2nd gen starter because i'm running a 47RH at the moment. But i think mechanically, starters are starters. I'd start poking around, but my '89 FSM is somewhere in the mail :x
Any pointers?
Re: Weird starter problem
Postby ellis93 » Sat Dec 10, 2011 3:53 pm
Sounds like either the Bendix or Solenoid. Take something heavy and bump the starter.
Oh ya check the battery connections first.
Postby cmann250 » Sat Dec 10, 2011 4:31 pm
ellis93 wrote:Sounds like either the Bendix or Solenoid. Take something heavy and bump the starter.
My connections are no worse than they have been before :oops: I gave it a couple bumps with a hammer...
Postby cmann250 » Thu Feb 02, 2012 12:27 pm
Just to get the info out there, it ended up being the shifter linkage. I didn't have it all the way in park :roll: Which explains why it came and went
Postby PToombs » Thu Feb 02, 2012 5:16 pm
And it only took 2 months to figure out? :roll: It sure sounded like a starter or electrical problem when you described it.
Postby Tacoclaw » Thu Feb 02, 2012 6:21 pm
And people wonder why I like standard transmissions so much. :lol:
Postby dazedandconfused » Fri Feb 03, 2012 5:13 am
PToombs wrote:And it only took 2 months to figure out? :roll: It sure sounded like a starter or electrical problem when you described it.
He pulled the 47rh and reinstalled his 727 about a month ago. Sometimes you just forget to post results.
Postby cmann250 » Fri Feb 03, 2012 5:22 am
When it happened with both transmissions, I figured it had to be something on the truck. I'm getting smarter :D
Tacoclaw wrote:And people wonder why I like standard transmissions so much. :lol:
Ask Pulltilbroke how a manual is without a NSS :lol:
Andy is right, I just wanted to get the info out there since everyone says "Search first!!!" to the newbs
Return to Electrical
