stacks
stacks
Postby remi » Tue Feb 14, 2012 8:30 pm
does anyone have pics of there stack piping below the bed
1992 w250, a518, fuel screw borderline runaway, denny t stage 2 fuel pin, cai,4 turbo back straight pipe to 5inch stack, 4 inch lift, 3 and 1 boost, egt, tranny temp,
remi
Re: stacks
Postby Tsbourne09 » Thu Feb 16, 2012 4:38 pm
I can get a pic but its down pipe to a straight 4inch pipe back to almost the end of the cab to a 4inch flex pipe to a 90* 4inch pipe to my t-pipe. all hels together with 4inch to 4inch clamps.... very simple.
Not On Yet: 60#VS
Tsbourne09
Re: stacks
Postby remi » Thu Feb 16, 2012 8:30 pm
well did you cut that crosmember of the bed and the one for the fuel strap support
remi
Re: stacks
Postby tim curran » Sun Feb 19, 2012 3:34 pm
:twisted: If u set back your exhaust pipe from the front of the bed and punch out a hole with a 4 inch hole saw you don't have to cut any cross members on frame or bed. Keep in mind state of maine is a stickler if don't have much of a muffler.
1993 w250, 3200 RPM springs, maxed fuel screw, industrial inj. Fuel pin, Dynamite diesel 75 horse inj., ind inj stage 2 pump, 60 lbs valve springs, ARP head studs, Banks ram air intake. 4 inch diamond eye exhaust,16cm turbo housing, 60 mm comp. Housing, BD tourqe converter, billet flex plate, Banks gauges, 212hp 608 tourque, old smokey and worn out.
tim curran
Re: stacks
Postby dazedandconfused » Sun Feb 19, 2012 3:54 pm
You only have one pipe coming up into the bed then a Y-pipe sitting in the bed.
Re: stacks
Postby remi » Sun Feb 19, 2012 7:10 pm
well you can do that but i dont like the look ive done it before
remi
Re: stacks
Postby tim curran » Sun Feb 19, 2012 7:21 pm
I used two 5 inch 90 degree exhaust stacks bases from a 2006 frieghtliner columbia they have a half inch threaded rod so u can mount them to a piece of angle iron I ran a 5" pipe between them and put the pipe from the bottom of the bed into the 5" pipe I then used a heat shield to keep debree off of the pipes this works great nice and rugged and it can be removed in no time
tim curran
Re: stacks
Postby dazedandconfused » Mon Feb 20, 2012 7:10 am
remi wrote:well you can do that but i dont like the look ive done it before
Well I've seen guys run them under the bed and melt the fuel tank. Besides then you don't see all the ugly piping hanging under the truck.
Re: stacks
Postby Tsbourne09 » Mon Feb 20, 2012 8:03 pm
I cut the crossmember.. Sorry i have not posted pics yet.
Not On Yet: 60#VS
Tsbourne09
Re: stacks
Postby remi » Mon Feb 20, 2012 8:44 pm
i really wanna see can you post pics please
remi
Re: stacks
Postby Tsbourne09 » Wed Feb 22, 2012 5:19 am
bad pics but its the jist of it. simple and cheap done from home...
ignore all the black melted plastic on my t pipe and the half melted mc donalds cup. lol. i have a new t pipe to go on it then i remove everything for paint.
Not On Yet: 60#VS
Tsbourne09
Re: stacks
Postby Diesel Dawg » Thu Feb 23, 2012 1:53 am
WHAT THE HECK DID YOU MELT WITH THAT THING!!!!! I always wanted stacks but now I dont know! :shock: :shock: :shock:
Diesel Dawg
Re: stacks
Postby Tsbourne09 » Thu Feb 23, 2012 6:19 am
This t pipe was on the 6.7 so it got realy freakin hot. They dont get hot enough on my 1st gen to really melt plastic...
Not On Yet: 60#VS
Tsbourne09
