Fuel pressure levels
Postby 93flatbed » Fri Feb 24, 2012 5:37 pm
I've gotten my self an air dog 165, I've set it to 17 psi with the engine running. I've since read that our pumps start to loose dynamic timing at the 7-8 psi range. So what is my beat option here? Do I just adjust the air dog down or do I get a regulator that is boost referanced? Opinions and options are needed, thank you.
93flatbed
Re: Fuel pressure levels
Postby mhuppertz » Fri Feb 24, 2012 8:56 pm
I replaced the pickup tube with 3/8" line, and put in 3/8" all the way to the piston lift pump and added a pusher electric pump, and my fuel pressure goes from 20 PSI part throttle to zero full throttle, so I feel your pain.
mhuppertz
Postby Tsbourne09 » Fri Feb 24, 2012 9:11 pm
i set my fuel pressure to 16psi via raptor150. can drop to 14ish at wot. i am curious to find out what that means about the timing you are talking about?
Not On Yet: 60#VS
Tsbourne09
Postby skilletky » Fri Feb 24, 2012 11:08 pm
I got a Fass 150/95 preset to 17 psi. Never drops pressure. Just called them today to have a 8 psi spring sent. I'm afraid of blowing out the front seal
skilletky
Postby Tsbourne09 » Fri Feb 24, 2012 11:15 pm
skilletky wrote:I got a Fass 150/95 preset to 17 psi. Never drops pressure. Just called them today to have a 8 psi spring sent. I'm afraid of blowing out the front seal
hmm... think i should cut mine down?
Not On Yet: 60#VS
Tsbourne09
Postby skilletky » Fri Feb 24, 2012 11:18 pm
Mines been set at 17 for 5 years now on 2 different ip's and I never had a problem. But it has always worried me.
skilletky
Postby 93flatbed » Sun Feb 26, 2012 6:48 pm
Bump
93flatbed
Postby Tsbourne09 » Sun Feb 26, 2012 9:32 pm
Ill bump back even harder...
Not On Yet: 60#VS
Tsbourne09
