Tacoclaw wrote:Not if it's warmed up and still smoking, though a 7x15 does seem pretty big.
Have you tried it with your KSB iwred hot? Might advance it some and give you an indication of whether it needs advanced or retarded.
skilletky wrote:Mine deffinatly get better once it warms up, but they still haze even then. Ellis, if they have the right spray angle, the Pop pressure is close to specs, and you have you timing set right they shouldnt haze. Maybe only a little. I think mine haze all the time because I have the pop pressure set lower than factory.
Users browsing this forum: No registered users and 74 guests
