The green wire on the regulator goes DIRECTLY to the field on the alternator, so there is only 1 potential problem spot on the ground side of the regulator.
FWIW, in my ventures to the yards I always keep my eyes out for older Mopar vehicles with the regulators that have the Mopar logo or brand on them, as I have found that even a 20-odd year old, "worn out" regulator is way better than the highest priced
JUNK these parts stores are pushing on us these days.
I fairly recently had a regulator go bad on the old flatbed, at 9:PM at night, in BF Arkansas.
I tore the whole truck apart and couldn't find the spare and I needed headlights, so knowing that the green wire is a switching ground, I rigged a system through the blower switch (variable resistance) and made it to a place with a parts store (200 miles) to wait 'till it opened up.
To operate the alternator, I flipped the blower switch to half speed, then pushed the "HEAT" button and waited until the voltmeter's needle spiked to full, then flipped the HEAT switch off to cool a few seconds, then repeat.
This was a fairly slow climb, and what I was doing was using the blower's resistance coils (located behind the ABS module) to slow the charge rate, so as to not overload and boil out the battery.
It wasn't a kosher repair, but it did the trick and I could probably have gone clear across the country that way.
