DTanklage wrote:dude, if you remove the top (that takes about what?, 5 mins?) all you do is put a socket or pc of pipe on the back side and knock one of the balls out with a punch. then you turn it over and hit it again and the other one falls out
then you pull the shaft, put it back in, tap the balls back in - and your done
