Lip in IC tubing
Lip in IC tubing
Postby GPSMatt » Thu Nov 08, 2007 12:16 pm
i dont kno if this is really the right place to post this but there really isnt a shop talk forum or anything... How do you get the lip in inter cooler tubing i have seen people weld a bead around the end of the pipe anyone kno of the tool and where i can get it?
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby DTanklage » Thu Nov 08, 2007 12:25 pm
i welded mine
you dont have to weld all the way around it
6 small beads would prolly keep it from pushing apart
i welded mine all the way around but mine are steel tubes
would be hard to keep bead small with alum
good luck finding a tool that puts a bead in tubing that small...
i used to runa a sheet metal shop and we didnt have anything that would do it
i am sure someone does...dunno where tho
DTanklage
Postby GPSMatt » Thu Nov 08, 2007 4:09 pm
i was thinking something like this
[img]http://www.harborfreight.com/cpi/photos/37300-37399/37354.gif
[/img]
but obviously it would have to be shaped diff to just expand and put the lip in it
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby TWorline » Thu Nov 08, 2007 4:52 pm
GPSMatt wrote:i was thinking something like this
[/img]
You could send it to me to roll the beads on or here is the tool that does it.
http://search.harborfreight.com/cpisearch/web/search.do?keyword=sheet+metal+fabrication+kit
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby GPSMatt » Thu Nov 08, 2007 5:01 pm
link didnt work?
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby TWorline » Thu Nov 08, 2007 5:06 pm
GPSMatt wrote:link didnt work?
Try it now.
Tim Worline
TWorline
Postby GPSMatt » Thu Nov 08, 2007 5:10 pm
ah 200 isnt a bad price at all how is the quality of it we all kno how HF stuff is its hit or miss
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby TWorline » Thu Nov 08, 2007 5:29 pm
It is designed to work 18ga. mild steel, I had to do some modifications to it to work my 16ga. stainless tubes. I have been using it for about a year now and have not had to remake anything yet.
Tim Worline
TWorline
Postby GPSMatt » Thu Nov 08, 2007 5:32 pm
that sounds prety good watd u have to do to get it to do the stainless?
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby TWorline » Thu Nov 08, 2007 8:36 pm
Just had to reinforce the throat to keep the rollers in line. With the added stress of thicker/tougher metal they wanted to walk away from each other and not keep the squeeze presure needed to make the beads.
Tim Worline
TWorline
Postby Philip » Thu Nov 08, 2007 9:58 pm
Tim the old model bead rollers that Eastwood used to sell does the same thing on the jaws.
I rolled the tubes on MiDon's 1st gen house. :D
Postby GPSMatt » Thu Nov 08, 2007 10:12 pm
thanks guys you've pointed me in the right direction a bead roller.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby TWorline » Fri Nov 09, 2007 5:45 pm
The first time I noticed the lack of squeeze pressure it was 2:00 in the morning and I had cranked for 3 minutes with nothing happening, severe brain fade! ;-)
Tim Worline
TWorline
