Installing cab lights, need measurements
both inside and out
Postby ramtough1993 » Tue Feb 28, 2012 7:50 pm
I bought a set of cab lights for my 93 but the truck didn't come with lights originally so i have no idea how to space them out to make them look stock and decent any help or tips would be greatly appreciated.
1993 Dodge Power Ram 150 4x4, 5.2L Magnum, Automatic Transmission, Work Special Package, Currently mostly stock
ramtough1993
Re: Installing cab lights, need measurements
Postby RumbleFish » Tue Feb 28, 2012 8:07 pm
here ya go!
borrowed this from dtr 100yrs ago.
Postby ramtough1993 » Wed Feb 29, 2012 2:10 pm
Thanks a lot, one more question, the lights need some paint but should they be blue like the color of the truck or silver?
ramtough1993
Postby RumbleFish » Wed Feb 29, 2012 3:21 pm
They're silver/grey from the factory. I like them painted body color though.
Postby ramtough1993 » Wed Feb 29, 2012 6:42 pm
yeah see these ones that i bought are a little weathered and could use a coat of paint, next challenge is to get them wired up
ramtough1993
Postby ramtough1993 » Sun Mar 11, 2012 6:06 pm
ramtough1993 wrote:I bought a set of cab lights for my 93 but the truck didn't come with lights originally so i have no idea how to space them out to make them look stock and decent any help or tips would be greatly appreciated.
Now that i have the lights all painted i am itching to get them on, is there any place that makes a replacement wire harness of does anybody have any idea on how the original wire harness looked or how it was all connected, i am looking for any tip i can get, any response is appriciated.
ramtough1993
Postby CUMMINSDODGEMAN3 » Fri Mar 16, 2012 8:11 am
Cant remember how the factory one are for the 1st gens but maybe this will work...http://www.ebay.com/itm/UNIVERSAL-TRUCK ... 41&vxp=mtr
CUMMINSDODGEMAN3
Postby Mark Nixon » Sat Mar 17, 2012 9:29 am
I'm sure I have a good stock harness or 2 around.
The harnesses are a parallel daisy chained affair, with the 1 long wire that has the female bullet connectors supplying power.
The housing wiring has loops for the grounds that the screws that retain the cab light run through.
Around the headlight switch is a female bullet connector that has a black wire with a yellow stripe on it, which is the connector for the cab light harness.
Postby ramtough1993 » Sun Mar 18, 2012 5:12 pm
OK, i think i am gonna by the ends and wire em up as simple as possible. Thanks for the tip on the black and yellow wire would have know how to connect it otherwise.
ramtough1993
Return to Body
