>>> WATER PUMPS <<<
>>> WATER PUMPS <<<
Postby BEARKILLER » Sun Mar 04, 2012 11:44 pm
As per the water-pump on an I/C 1991, what years are interchangeable ??
What are the better, more reliable, pumps to use --- part-numbers please ??
NAPA has a DELPHI that states "same as original issue" for about $80; is this a good pump ??
Thanks.
MY TRUCK = 1985 FORD F-350 2wd, 89 1st.Gen.Cummins,Getrag 5-sp,Dana70 3:55
WIFE'S TRUCK = 1991.5 D-250 I/C, Auto
SON'S TRUCK = 1990 W-250 Getrag
#4 = 1991 D-350 LE Getrag
BEARKILLER
Re: >>> WATER PUMPS <<<
Postby PToombs » Mon Mar 05, 2012 5:59 pm
They should be the same right up to a 3rd gen. Some have a shroud on the face of the impeller, not sure if that's an updated or just a different manufacturer thing.
Postby Black93 » Mon Mar 05, 2012 6:33 pm
I got mine from this place on ebay. It's been 2 years now with no problems.
http://www.ebay.com/itm/Dodge-Cummins-D ... es&vxp=mtr
Black93
Postby nolafishr » Fri Oct 05, 2012 5:26 am
I will be changing mine out also, Do you know what the torque is for the water pump bolts?
nolafishr
