crank positioning sensor
Postby Hansen01 » Mon Mar 05, 2012 5:17 pm
Any one know what its spose to be set at? We took it off to change the front seal on dads 93 set it to .050 and now none of the gauges work like they used to, especislly the temperature gauge, when he turns the lights on the temp gauge goes up, what gives?? Lol
Under construction...
Hansen01
Re: crank positioning sensor
Postby PToombs » Mon Mar 05, 2012 5:42 pm
Supposed to be.050. Sounds more like a bad ground someplace. Check the sensor plug too, sometimes they get kinda greenish in there.
Postby Hansen01 » Mon Mar 05, 2012 6:29 pm
Ok that's what i thought it was spose to be set at, was gonna regap and check that tomorrow, thanks :D and people say that you don't make useful posts :lol:
Hansen01
Postby Hansen01 » Tue Mar 06, 2012 3:55 pm
Well, I adjusted it today and it was a little tight, and I think it made a little better, but gauges still move a bit when i turn the lights on, what ground could this be or what area? Or maybe Jus mess with the sensor more?
Hansen01
Postby PToombs » Tue Mar 06, 2012 5:48 pm
Check them all, battery to core support, head to firewall, and under the dash, right of steering column on a metal bracket.
Postby Hansen01 » Tue Mar 06, 2012 9:08 pm
thank you :salut: will have to look for them tomorrow,
Dad also became a member of the pull cable club today :lol:
Hansen01
Postby Richie O » Fri Mar 09, 2012 9:41 am
I don't suspect the crank sensor would cause those problems. Im with Pete, check other stuff. When the sensor goes bad they stop charging, tach ( if equipped ) stops working, a/c, and some other stuff.
Postby Hansen01 » Fri Mar 09, 2012 6:20 pm
ok, well the only reason we thought it was that was because everything worked fine before we took it apart, but will look for grounds when i get the chance and report back, thanks guys :D
Hansen01
Postby Hansen01 » Mon Mar 12, 2012 3:07 pm
Got it figured out yesterday. it ended up being the ground that goes from the battery to the core support, thanks guys! :D
Hansen01
Postby PToombs » Mon Mar 12, 2012 5:10 pm
toldjaso! :mrgreen:
Postby Hansen01 » Mon Mar 12, 2012 5:14 pm
That you did :D
Hansen01
Return to Electrical
