Oil pressure gauge
Oil pressure gauge
Postby Tsbourne09 » Fri Mar 02, 2012 9:52 pm
Hey everyone! Where is the best place to took up an aftermarket oil pressure gauge and what should be a good oil pressure to have? Think i can just go to orileys or autozone and get a brand the sell there... Im goin to do it this week
Not On Yet: 60#VS
Tsbourne09
Re: Oil pressure gauge
Postby skilletky » Fri Mar 02, 2012 9:55 pm
Hook where the factory sending unit goes IMO . That's we're I had mine. Get a 100 psi gauge. Mine cold was about 70 to 80 and after it got hot was around 25 to 30 at idle.
skilletky
Postby Tsbourne09 » Sat Mar 03, 2012 1:27 am
Mechanical or electric... Or does it matter. All my isspros are electric.
Not On Yet: 60#VS
Tsbourne09
Postby Bschwarzli » Sat Mar 03, 2012 6:54 am
Yes. Go Into the factory location. Just remove the old and install the new.
You want electric. If the mechanical (means you have oil in a tube that you have to feed into the cab) even cracked, you would not only have oil everywhere, but I you did not know it on a long drive you could use up your engine oil!!!!
And good choice on a quality gauge brand. :)
Edit: was just reading and noticed I was thinking of the gauge brand from the last thread I was reading!!
No, don't go generic!! Go isspro, autometer, etc. don't risk a faulty reading off a cheap gauge then fry your engine. I see bgilbert won't agree with this but.....;)
1993 W350 Dually Crew Cab - 1997 12V, NV5600, NP205, Dana 60 F, Dana 80 R, Gear Vendors, PDR Twins, 4 link rear, so mostly stock really :)
1990 W250, NV5600, 3.07s, Gear Vendors, Super HX40, kinda stock :D
Bschwarzli
Postby bgilbert » Sat Mar 03, 2012 7:20 am
I always use the 1/8npt port Cummins gave us to check/monitor oil fuel pressure at the oil filter mount. You can go electric or mechanical at that point. With the mechanical gauge, use copper tubing if it makes you feel safer. Even though the factory gauges are worthless, I still like them to work. Something doesn't look right with a dead OEM gauge IMO. Also I prefer Isspro for the boost and pyro, but el cheapo for oil pressure. In my experience oil pressure gauges tend to crap out or have issues over time. So you won't feel bad if you have to replace an el cheapo gauge.
Bill Gilbert
Postby Tsbourne09 » Sat Mar 03, 2012 2:28 pm
Thank you guys a lot!!!
Not On Yet: 60#VS
Tsbourne09
Postby Tsbourne09 » Wed Mar 07, 2012 11:50 pm
well i diddnt get a isspro like my other matching gauges but i did spend $60 ish on a nice autometer 100psi one. hooked it to the open spot on top of the oil filter housing. mounted the gauge in a nice pod from genos on top of the steering coloume. thanks for the help guys!
just thought id share a vid i took goin down the road. crusing boost to 50psi boost!!!!
http://s1130.photobucket.com/albums/m53 ... G_0997.mp4
more pics, just felt like shareing... lol
Not On Yet: 60#VS
Tsbourne09
Postby skilletky » Wed Mar 07, 2012 11:56 pm
I'm digging the blue dash lights. Are those led? I want to put red in mine.
skilletky
Postby Tsbourne09 » Thu Mar 08, 2012 12:18 am
yea. all blue led bulbs and wite face gauges (white stickers from whitefacegauges) thanks! they have red
Not On Yet: 60#VS
Tsbourne09
Postby skilletky » Thu Mar 08, 2012 12:28 am
I'm gonna have to get me some. I like blue but all my vatopeters are red. Plus red is a little easier on the eyes at night
skilletky
