artificial boost
artificial boost
Postby cummins king » Fri Nov 09, 2007 11:10 pm
k hears a far feched idea,
what would happen if you put air into ur motor from a compressor, u would need one inch line that went into ur inercooler tube
this would me that u could instancely biuld ?30psi, then ur big turbo would kick in, this would work great on a dyno, but in a drag race u could have a tank thats peloaded to 150psi and have a one inch line going to ur ic tube, with a big dump valve. u ounly need one good blast for 10 seconds, thats about how long it would take a tank with a 1inch line to empty. (im talking about a tank u would find on a big truck)
93 4X4 auto
cummins king
Postby GPSMatt » Sat Nov 10, 2007 12:21 am
the volume of air would have to be huge you would need a really really big tank
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby cummins king » Sat Nov 10, 2007 8:40 am
ya one of of a semi truck like the one thats kiking around in my shop
93 4X4 auto
cummins king
Postby flashgordon » Sat Nov 10, 2007 10:59 am
cummins king wrote:ya one of of a semi truck like the one thats kiking around in my shop
Compressors are grate to build high PSI, but are vary slow to build the volume. and it would take a lot.
On top of that, the air would want to go both way's and the bad way would try and stall the compressor wheel of the turbo.
Flash.
flashgordon
Postby ford69557ci » Sat Nov 10, 2007 11:11 am
there is a big rig drag truck with 6 turbos in diesel power mag and it says somethin about using compressed air to spool up the turbos but not sure how
ford69557ci
Postby gomerpile » Sat Nov 10, 2007 3:31 pm
well i know this sounds stupid, but me and a friend of mine took a toyota cellica and a leaf blower and rigged it up so that we could drive with it on there, and for a redneck turbo, it made somegood power. and it would make the volume part
1992 Dodge D-250 LE auto, LSD w/3.54, about 200,000+ miles.Isspro Pyrometer , Sunpro tach,Tractor Supply Boost Gauge, Old Smokey Fuel Pin,4 turns on fun srew, starwheel turn CCW 1 turn, 40hp injectors, BHAF,16 cm housing.Sony Head Unit.
gomerpile
Postby cummins king » Sat Nov 10, 2007 3:40 pm
:lol: :jumpsmile: a leaf blower
what month was the 6 turbo one in i cant remember, but if u have a one way valve just before the artificial air injection(in patining that name) the air would flow into the motor, you only need a full tank for the strip then u can re fill it, or if u have an electric compressor and only us it when a corvet pulls up u would be in good shape :evil: for the street
93 4X4 auto
cummins king
Postby GPSMatt » Sat Nov 10, 2007 11:07 pm
gomerpile wrote:well i know this sounds stupid, but me and a friend of mine took a toyota cellica and a leaf blower and rigged it up so that we could drive with it on there, and for a redneck turbo, it made somegood power. and it would make the volume part
Wow.
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby swank » Sun Nov 11, 2007 12:43 am
truck
swank
Postby GPSMatt » Sun Nov 11, 2007 1:18 am
swank wrote:kinda like this?
http://www.youtube.com/watch?v=ZCNCtnWCNrg
hmm wtf is that lol
86 F350 idi
95 Lightning
85 GT
GPSMatt
Postby cummins king » Sun Nov 11, 2007 6:56 am
one big ars turbo
93 4X4 auto
cummins king
Postby PToombs » Sun Nov 11, 2007 2:08 pm
Swanks gonna be jet powered! :2cool: :wrench:
Postby mhuppertz » Mon Nov 12, 2007 8:56 pm
I know there was a company selling an electric supercharger but it was wimpy, like 2PSI max.
Oh, here ya go:
http://www.electricsupercharger.com/
http://www.turbomagazine.com/tech/0406t ... index.html
http://www.autospeed.com/cms/A_2063/article.html
mhuppertz
Postby cummins king » Mon Nov 12, 2007 9:50 pm
thats all great if u got a fart car
im talking about using compressed air to spool up be turbos
93 4X4 auto
cummins king
Postby mhuppertz » Tue Nov 13, 2007 6:09 am
cummins king wrote:thats all great if u got a fart car
A better idea would be to dump compressed air into the exhaust manifold to spool up the turbo just before you dump the clutch. I'd actually like to try that!
mhuppertz
