Trade or Upgrade?
Re: Trade or Upgrade?
Postby Dieselwrencher » Thu Mar 15, 2012 11:46 am
I wouldn't do a 4x4 swap without a donor to use. You will go nuts buying all that little stuff you'll need. I know where there is a pretty nice 92 Ex cab long box auto that could be baught right.
2000 Excursion VE 24v 47RH 4x4
1976 Chevy K30 Crew Cab Short box P-pump 12v 47RH
1972 Chavy K30 P-pump 24v 47RH
1968 Corvette 5.9 47RH
Dieselwrencher
Postby meby » Thu Mar 15, 2012 6:49 pm
Dieselwrencher wrote:I wouldn't do a 4x4 swap without a donor to use. You will go nuts buying all that little stuff you'll need. I know where there is a pretty nice 92 Ex cab long box auto that could be baught right.
Details?
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby Dieselwrencher » Fri Mar 16, 2012 3:29 pm
1992 W250 LE 4x4 5.9 Auto good tires regular cab (Sorry I thought it was an extended cab) long box 201k, pretty clean one spot of rust about the size of a half dollar on the rh lower area of the front fender. White with silver down the middle. Factory fender flares on it. A crescent shaped rust spot on the left rear box side. $6k I can PM you his number.
Dieselwrencher
