Car finally running (video)
Postby Deathrod » Fri Mar 16, 2012 10:26 pm
http://www.youtube.com/watch?v=KC7IB7WmtTQ I got it running and think i have most of the bugs out of it, its by no means done....no glass, gauges in the mail, body work/ paint, but it runs!!!!
Deathrod
Re: Car finally running (video)
Postby AHineman » Sat Mar 17, 2012 3:34 am
Awesome! 8)
Postby ellis93 » Sat Mar 17, 2012 4:09 am
It sure is 8)
Postby 1arock » Sat Mar 17, 2012 12:30 pm
Golly Gee Whiz Crap Damn Wow Tooo Coool Luv Luv Luv IT, :mrgreen: Rocky
92W250 w/a 68D100 skin,tach, pyro, boost, trans temp guages, rebuilt a518 w/a PTC converter, 4in muffeled exhaust, 3200 gov spring, he351cw,M@H dynamic timing, 5x12s,M@H M3 pin, pump jacked with, 3.54s, 6+ lift, 14.5x36r rubber,nearly done,"What was I thinking?"
1arock
Postby cmann250 » Sat Mar 17, 2012 4:07 pm
Man, that thing is as slick as can be!
Postby captmatthew1 » Sat Mar 17, 2012 8:44 pm
That thing is freakin awesome!
1992 W250 5 speed, pump maxxed, 366 spring, caravan seats, white gauges, more to come.
captmatthew1
Postby hemislave » Sat Mar 17, 2012 8:47 pm
Waaaaay Cooool ....
85 crew cab 1st gen ve pump tweaked a lil. 4:10s auoto o/d gauges boost,pyro. 16cm exhaust housing .285/75/16 nitto terra grapplers,rebuilt a518 w/a decent torque converter.
hemislave
Postby autocar56 » Sun Mar 18, 2012 3:35 pm
Insane!! very nice
91.5 4x4,5 speed, pump timing 1/16, fuel screw 1 turn, ground down pin, k/n air filter , stacks, 160,000 miles
autocar56
Postby oldestof11 » Sun Mar 18, 2012 5:03 pm
Nice! 8)
Postby dazedandconfused » Sun Mar 18, 2012 6:40 pm
That is slick.
Postby Dieselwrencher » Mon Mar 19, 2012 1:10 pm
Very cool rod! I like the air ride and great detail on cleaning and painting the engine! It looks great!
2000 Excursion VE 24v 47RH 4x4
1976 Chevy K30 Crew Cab Short box P-pump 12v 47RH
1972 Chavy K30 P-pump 24v 47RH
1968 Corvette 5.9 47RH
Dieselwrencher
Postby CUMMINSDODGEMAN3 » Mon Mar 19, 2012 2:50 pm
VERY cool! on bags or air shocks doing that? front only looked like shocks..
CUMMINSDODGEMAN3
Postby captmatthew1 » Tue Mar 20, 2012 6:01 am
I saw bags in the front. So I would have to assume he did the same in the rear
captmatthew1
Postby ahale2772 » Tue Mar 20, 2012 8:34 am
so cool...
Postby Deathrod » Tue Mar 20, 2012 11:17 am
It's bagged all around...managed to fit all 8 valves, air compressor, air tank, battery, speaker box, and 2 11 gallon fuel tanks in the rear. But I'm in the hospital....wife had my son today, so won't be doing much of anything to it this week. Got all matching isspro guages in the mail....building dash should be a mess!!!
Deathrod
