Vent window seals?
Vent window seals?
Postby Diesel » Tue Mar 20, 2012 8:09 pm
Where can I find new vent window seals? They are leaking. I have seriously replaced everything rubber on this truck trying to stop the leaks!
1991.5 D250 Intercooled A518
Diesel
Re: Vent window seals?
Postby CUMMINSDODGEMAN3 » Wed Mar 21, 2012 5:57 am
Rockauto.com has a kit i just bought that had front and rear window channels and inner and outer blade scrapers for both doors..
Team Green's old hauler 05 3500 CTD 4x4 6sp 8in rize industries lift, 37 Toyo M/T's, Smarty, Edge Att, AFE intake, ATS manifold Borg Warner turbo, 5in SS MBRP
90 W350 CTD SRW big pump, big turbo, lots of fuel, 47RH billet suncoast triple disc and 20's
93 D250 CTD ext cab pump work, POD's
CUMMINSDODGEMAN3
Postby Diesel » Wed Mar 21, 2012 6:23 am
I dont need seals for the actual windows. I need seals for the triangle vent windows that rotate open.
Diesel
Postby CUMMINSDODGEMAN3 » Wed Mar 21, 2012 6:48 am
AND those are expensive! let me see if i can find where i just seen them a few days ago..
CUMMINSDODGEMAN3
Postby CUMMINSDODGEMAN3 » Wed Mar 21, 2012 6:51 am
CUMMINSDODGEMAN3
Postby Diesel » Wed Mar 21, 2012 7:16 pm
$90 per side!!!!
Diesel
Postby jorez » Mon Mar 26, 2012 6:43 am
I just picked up a full set to do both windows. Is there a trick to getting the upper and back seals out? Is there a clip..or screw? I know how to get the felt scraper out...shoot, they are almost falling out now as it is! LOL
jorez
Postby CUMMINSDODGEMAN3 » Mon Mar 26, 2012 7:23 am
Pull straight up like towards top of door
CUMMINSDODGEMAN3
Postby GoldenRule » Sat Sep 15, 2012 12:04 pm
I was told these will fit as well and are only $45 for both sides. I'll order a pair and report back. Whistle is often caused by a failing locking mechanism though and if the lock is bad, rubber seals won't help much.
http://www.dodgeconnection.com/catalog/ ... 555507.htm
GoldenRule
Postby Diesel » Sat Sep 15, 2012 1:23 pm
GoldenRule wrote:I was told these will fit as well and are only $45 for both sides. I'll order a pair and report back. Whistle is often caused by a failing locking mechanism though and if the lock is bad, rubber seals won't help much.
As in my locks aren't holding tight enough? Would you say they should be replaced or a spacer put under them? Can I still get new one?
Diesel
Postby GoldenRule » Sun Oct 07, 2012 11:59 pm
The spacer might work for a while, but I read a good thread on rebuilding them and actually fixing the problem. Replacement is best if they look anything like mine. I found some at the junkyard that seem functional and I'm going to switch them out. I'll try to find that link and post it here.
GoldenRule
Postby GoldenRule » Mon Oct 08, 2012 12:04 am
GoldenRule
Postby kd0ezq » Sun Aug 04, 2013 9:29 am
Do you actually use the vent windows? I do not. I used urethane like for a windshield and glued mine shut. No whistle and no leaks....
kd0ezq
Postby Diesel » Mon Aug 05, 2013 5:33 am
I love my vent windows! I found out that my major leak is actually my missing bushing on the door hinge letting water in at the bottom. Going to first rebush the hinges and see where I'm at.
Diesel
