Re: Back to Progress (never ending)
Postby Tacoclaw » Thu Mar 22, 2012 6:10 am
Damn right you will, how can you deny this it's power steering?
I also bumped my oil feeds up to -6. Hydraulic hose too, just in case my relief fails and my oil pressure jumps to a couple thousand pounds. ;-)
Postby Tacoclaw » Sun Mar 25, 2012 8:40 am
Got the core support bolted back together and the radiator and hoses back in. It's ready for water and startup, but some filthy heathen ran off with my power steering line to the gearbox. I've just been picking up around the garage, which it has badly needed, since it looks like someone set a car bomb off in it.
I did happen to find my old tamper-proof cap for my smoke screw. Think I'd fool anyone if I put it back on the pump? :mrgreen:
Postby JustinRhodes » Sun Mar 25, 2012 8:49 am
Tacoclaw wrote:Got the core support bolted back together and the radiator and hoses back in. It's ready for water and startup, but some filthy heathen ran off with my power steering line to the gearbox. I've just been picking up around the garage, which it has badly needed, since it looks like someone set a car bomb off in it.
Check your texts gay boy :D
JustinRhodes
Postby Tacoclaw » Sun Mar 25, 2012 8:53 am
JustinRhodes wrote:Check your texts gay boy :D
Hineman, Justin wants you to check your texts!
Postby AHineman » Sun Mar 25, 2012 10:57 am
Levi, just because you two want to live like that, doesn't mean the rest of us do. :roll:
Postby Tacoclaw » Sun Mar 25, 2012 3:00 pm
Sounds like somebody's jealous huh, Justin. :mrgreen:
Anyways, I am ready to fire minus the power steering not having fluid in it. I threw it all together in anticipation of how it'll look. This is it, minus blankets and maybe some paint on those IC pipes.
Also, here's my electric fan setup. Not wired up yet, but I'll just do that as time allows once it's moving around again. I'll stick some foam between the shrouds and the core so they'll actually pull through it.
Postby JustinRhodes » Sun Mar 25, 2012 3:18 pm
Sounds like it lol
It looks like your oil fill cap is crooked by the way :lol:
JustinRhodes
Postby Tacoclaw » Sun Mar 25, 2012 6:08 pm
I think your eyes are crooked. :P
Postby ivel_86 » Mon Mar 26, 2012 11:36 pm
Well I have spent the last day and a half reading thru this entire thread... looks awesome man. Cant wait to see/hear videos of it running. GOod luck.
US ARMY SGT
OIF 08-09
'93 W250, 4in Sky Lacker 35in Kelly Safari, Pump turned up, Fuel Pin ground, Pyro and Boost gauges, Straight piped, Home made air cleaner assembly.
ivel_86
Postby revemup15 » Tue Mar 27, 2012 6:05 am
I like the green
94 p-pump
revemup15
Banned
Postby Tacoclaw » Tue Mar 27, 2012 7:03 am
Thanks for the comments, guys.
I feel kind of bad, because there's not even close to a day and a half's worth of info in this thread. :lol:
Postby ahale2772 » Tue Mar 27, 2012 9:12 am
better make double sure everything is good before you start it, crappy to start it needing to break in the cam then have to shut it off to fix a leaky line or something.
looks good though, send me some tight 90* bends and i'll make you that nice intake plate that you want 8)
Postby CUMMINSDODGEMAN3 » Tue Mar 27, 2012 10:00 am
maybe you already said or not, i didnt see anywhere, but is that the onan (cummins) green?
Team Green's old hauler 05 3500 CTD 4x4 6sp 8in rize industries lift, 37 Toyo M/T's, Smarty, Edge Att, AFE intake, ATS manifold Borg Warner turbo, 5in SS MBRP
90 W350 CTD SRW big pump, big turbo, lots of fuel, 47RH billet suncoast triple disc and 20's
93 D250 CTD ext cab pump work, POD's
CUMMINSDODGEMAN3
Postby Tacoclaw » Tue Mar 27, 2012 10:43 am
The color is Detroit Diesel Green or Alpine Green. I never looked into a Cummins Green as I wasn't aware there was one. :oops:
Oh well, the DD Green is just offensive enough to Cummins guys to be perfect. 8)
Alex, what is the breakin routine for these cams? I've started to look around for one, or call Zach, but since I've still got a day or so I haven't sweated it too badly yet. I've also started sniffing around for an IC'd radiator and Thermostat housing, but I don't know if it would bolt up to my core support...
Postby CUMMINSDODGEMAN3 » Tue Mar 27, 2012 11:28 am
yeah, onan generators are a green like that which is part of cummins...
CUMMINSDODGEMAN3
