Hegemone wrote:I have a pretty nasty squeal coming from the tensioner assembly, seems to be from the 'joint' rather then the pully. Just was wondering if there was any way to adjust this that would take care of the sqeal before I drop this $60 replacement in. Thanks.
PToombs wrote:Cummins tool for what? Changing it? It's a regular metric bolt that holds it on. To put the belt on just throw a breaker bar or ratchet on it and pull it back. Getting the belt lined up is fun, I use a tiedown strap to hold the ratchet while installing the belt. Or I just struggle with it.
