1993 lift pump pressure?
Postby TRACTJDS0428 » Fri Mar 30, 2012 9:17 am
does anybody know what the lift pump pressure should be? diaphram style. before the fuel filter.
TRACTJDS0428
Re: 1993 lift pump pressure?
Postby cmann250 » Fri Mar 30, 2012 9:45 am
1. Welcome :D
2. My '89 FSM tells me 3-5 PSI is what it should be at cranking speed. If your truck is turned up, I'd want more. The max pressure a stock VE will handle is 12-15 PSI
Postby fatty » Fri Mar 30, 2012 10:18 am
cmann250 wrote:The max pressure a stock VE will handle is 12-15 PSI
I don't know why this keeps popping up but it simply isn't true. My Airdog has been pushing a little over 20 psi for about 2 years now with not a single issue.
Postby Tacoclaw » Fri Mar 30, 2012 10:46 am
While its not the max it can handle, it's the most I would want pushing on a stock(unknown) IP seal. Just because nothing has happened to you doesn't mean it won't happen to some poor sap who's just trying to get his truck back on the road.
Postby Philip » Fri Mar 30, 2012 6:49 pm
3 to 5 PSI is what the stock lift pump is rated for. With production standards this can vary quite a bit. My replacement pump from cummins runs 7 PSI after filter and 9 PSi before filter.
There is a 2 PSI drop threw the stock fuel heater and filter assy, with a new filter installed.
Postby TRACTJDS0428 » Mon Apr 02, 2012 8:51 am
THANK YOU ALL FOR THE ANSWERS. IF I WAS GOIN TO INSTALL AN ELECTRIC FUEL PUMP DO I NEED TO BYPASS...REMOVE... OR JUST RUN THRU THE STOCK LIFT PUMP? INSTALLED A NEW LIFT PUMP AND IT CRACKED AT THE INLET. LOOKING FOR ALTERNATIVES.
TRACTJDS0428
Postby Tacoclaw » Mon Apr 02, 2012 9:16 am
You can run through the LP, but if it's a diaphragm style and it tears for whatever reason, you'll have fuel pumping into your oil that much faster.
Any of what you posted are viable options, and the fuel pump just uses a generic block off if you decide to take it off.
Postby oldestof11 » Mon Apr 02, 2012 2:14 pm
Welcome! I would bypass.
After fatty challenged me a couple of years ago with the "cannot handle more than 15psi", I cranked my old Walbro 392 up to 20psi prefilter. No problems.
Postby quickie70 » Mon Apr 02, 2012 6:47 pm
my stock replacement from advanced auto parts (yeah, I know... should be cummins. It failed far from home and I put in what I could) is 15-17 prefilter. It helped find the weak seals in the original 200K VE pump in about 1000 miles. It'll pull down to 6 or so if I'm really romping on it. I'll stick with it for now!
1991.5 RCLB 4x4 LE Rag w/ 3.54's 200,000+ miles, original denny T, WH1C, P/S I/C with coolertubz, pump turned up slightly, DDP stage 1's, gauges (lots of em). Custom Anti-Rusting-undercarriage 15/40 coating provided by leaky timing cover. 306 HP / 599 TQ.
quickie70
Postby TRACTJDS0428 » Wed Apr 04, 2012 8:50 am
ok thanks again. What would the first recommendation be on an eletric replacement? prefferably somthing the will have the block off plate so i can remove the stock lift pump? Looked in geno's and i see some pump that look to have a block off plate attached, anybody have one? ...and how well do they work?
TRACTJDS0428
Postby CumminsPower59 » Wed Apr 04, 2012 10:15 am
Several of the guys on here run Holley Black or there is the Carter 4601?. From what I have read, the Holley isn't rated for #2, but works well. As for a block off plate, any generic type should work. Have you looked into a Low Pressure Piston Lift Pump? It is similar to the 2nd gen lift pump, just puts out a lower psi that works well with the VE. I have found a site that has the parts needed for the swap, I think it was gonna run me about $140 for everything to convert mine. Beats some of the other places that sell kits at $200+ ;)
Postby oldestof11 » Wed Apr 04, 2012 5:51 pm
Chevy small block fuel pump delete plate fits over ours.
Postby TRACTJDS0428 » Thu Apr 05, 2012 9:09 am
ok low pressure piston pump... where can i get it and what am i looking for? just a secound gen lift pump thats regulated or special part from a certain source? in know geno's has the 2nd gen lift pumps but dont remember seeing any low pressure descriptions. ill try that if i can find one.
TRACTJDS0428
Postby cmann250 » Thu Apr 05, 2012 9:47 am
TRACTJDS0428 wrote:ok low pressure piston pump... where can i get it and what am i looking for? just a secound gen lift pump thats regulated or special part from a certain source? in know geno's has the 2nd gen lift pumps but dont remember seeing any low pressure descriptions. ill try that if i can find one.
Oregon Fuel Injection has them. They're $60, but they aren't officially blessed by Cummins. The Cummins ones are $180. It's about $80 the line, gaskets, spacer and such
Postby TRACTJDS0428 » Fri Apr 06, 2012 9:36 am
cool ill check that out and see what i can come up with. what are everybodies feelings on fuel pins? ive seen them and i have turned my stock pin to the deepest point.
TRACTJDS0428
