BILTIT wrote:Did you get the coolertubz for the PS IC install? If so they use a 3.25''. The normal cooltertubz use 3''. You should be able to see the expanded end (~3'' long) if they are the PSIC tubez.
The_Head wrote:BILTIT wrote:Did you get the coolertubz for the PS IC install? If so they use a 3.25''. The normal cooltertubz use 3''. You should be able to see the expanded end (~3'' long) if they are the PSIC tubez.
No I got the normal cooler tubez as I had a stock intercooler at the time. I don't think the ps cooler tubez were an option quite yet.
Users browsing this forum: No registered users and 74 guests
