1993 lift pump pressure?
Re: 1993 lift pump pressure?
Postby CumminsPower59 » Fri Apr 06, 2012 10:02 am
I ground my stock one, it works well for $Free.99. Just like other things, there are several to choose from and it depends on how you want to use your truck ;)
Postby Black93 » Fri Apr 06, 2012 6:40 pm
I'm running an M2, but I kinda wish I'd went with an M3.
Black93
