before and after pics
Postby GPSMatt » Wed Nov 14, 2007 12:54 pm
that thing gets it prety hard.
86 F350 idi
85 F350 crew cab 4x 5.9
95 Lightning
85 GT
GPSMatt
Postby flashgordon » Wed Nov 14, 2007 3:31 pm
GPSMatt wrote:that thing gets it prety hard.
Yeah when he fired it up at the track, sounded good and smelled good to but when he left the line, i was truly impressed.
He tried some smaller lighter tires (30 pound a piece lighter) but couldn't make them hook of the line and got some real bad torque steer at about 60 feet, with then.
I tried to talk him into some drag radials but with all the cash he thrown into that motor and tanny theres nothing left for tires.
He was after a 6.99 1/8 E.T. but until we get a concrete starting pad.....theres no chance.
The tar is so cores that street tire actually grab better the slick, if you can believe that! :thumbdown:
I did run my diesel down that track, so when i get my turbo/intercooler installed. I will be able to compare it next year.
Flash.
flashgordon
Postby ford69557ci » Wed Nov 14, 2007 5:33 pm
thats one sweet ford. i have a 75 highboy witha 428 but its a mild engine and the truck is about to rust to the ground kinda give me some ideas though
ford69557ci
Postby flashgordon » Wed Nov 14, 2007 6:15 pm
ford69557ci wrote:thats one sweet ford. i have a 75 highboy witha 428 but its a mild engine and the truck is about to rust to the ground kinda give me some ideas though
Ya i don't now any thing about fords, but he called it a 428 side oiler and i said.........O ok :bball:
Flash.
flashgordon
Postby ford69557ci » Wed Nov 14, 2007 6:54 pm
the 427 side oiler is what shelby used in alot of the 427 cobras i doubt thats what it it cuz well just a set of the orignal tunnel port shelby heads are worth like 6000 on up and i think to buy one of the shelby side oiler reproduction engines from shelby is like 50 000
ford69557ci
Postby DTanklage » Wed Nov 14, 2007 7:21 pm
i have heard people talk of a 428 side oiler
not the huge 427 (hemi head) motor
but a 428
but you know how people throw around terms so who knows...
if it is really a side oiler you can tell by looking at the block
(from the outside)
DTanklage
Postby flashgordon » Wed Nov 14, 2007 7:26 pm
427? 428? i don't know, but side oiler i do
Also i know is that he's got at least 18,000 in to it and what ever heads he has they were sent out and professional ported.
and the intake had to have some sort of sealing idea figured out because the push rod go directly thru the intake port(My self thinking.......this is a stupid idea.......but it runs)
He's been collecting part and building this motor for almost 5 year and was fired up it's first time this spring.
The truck original intention was to be a tractor puller, then a mud bogger.......then.........well we got this race track open up in our home town and well...........he's hooked on drag racing. :lol:
Flash.
flashgordon
Postby ford69557ci » Thu Nov 15, 2007 8:04 pm
well if it has pushrods through the ports then it is most likely a 427 side oile and those are probably a set of shelby tunnel ports sweet i wonder where he found that stuff
ford69557ci
Postby KTA » Thu Nov 15, 2007 8:13 pm
That Ford in Vegas was no doubt Richard Madsens Cummins powered Crew cab. It is around 800-1000rwhp depending on where it is dynoed.
That white Gas Ford needs a bunch more ponies only 86mph in the 1/8th? I am over 93mph in the 1/8th and am shure to be a ton heavier. :lol:
Postby flashgordon » Fri Nov 16, 2007 1:06 am
KTA wrote:That Ford in Vegas was no doubt Richard Madsens Cummins powered Crew cab. It is around 800-1000rwhp depending on where it is dynoed.
Well here i go sticking up for the ford guy again :roll:......... :lol:
The mile per hour is a guess, the timing equipment has finish line E.T. only.
Were hoping to put 60" and mile per hour sensor in next year...........
Flash.
flashgordon
