Whats going on?
Postby PToombs » Sun Aug 24, 2008 4:27 pm
If it's sucking air, it will smoke like that. Not getting enough fuel to burn good. I think DPuckett had the same problem.
Postby Okie Smokie » Sun Aug 24, 2008 5:04 pm
I am in the middle of a rebuild due to "white smoke". White smoke is unburned fuel. Either the timing is way off, as noted previously, an injector has crapped out and is not atomizing the fuel, or you have a compression problem. I had an injector crap out, which in turn ruined my #6 piston and now I have a compression problem. What was your original problem causing you to change the injection pump?
'93 W250 Extended Cab, P7100, F1 Spartan, Extra Air, Tim's cooler tubes
'92 D250 Reg Cab, Flat bed, 5 speed, Bone stock
'91 D250 Reg Cab, Auto, Bone stock
Okie Smokie
Postby dpuckett » Sun Aug 24, 2008 6:49 pm
I'd start by checking the timing, or just advancing it about 3/16" for diagnostic purposes. I R&Red a pump one time and somehow, the pump gear jumped a notch backward, retarding my timing. Popped the gear off the pump, moved the pump back an inch, realigned the gear, and all was well.
I had the same symptoms you have- rough idle, white smoke to make a skeeter fogger jealous, no power, etc.
If the timing checks out, time to spray every line with ether (to evaporate any gunk or fuel), and let it run. Check for seepages. You could well have a pinhole like Cummins Pride mentioned.
Good luck, keep us posted on what works and what doesnt. Isnt online diagnostics fun?
Daniel
Postby Ezra » Sun Aug 24, 2008 9:08 pm
I broke off a lever when installing the 366 spring.. :sad: ..
ha ha yeah,I'm just glad you guys are out there..:D...
93 W250,auto,3.54's..167k miles..asa modified intake.stans 4in,.industrial injection pump.6x.016's..S300 62/71/14..piston lift pump..And still more to come.
Ezra
Postby Ezra » Mon Aug 25, 2008 8:53 pm
Ok sorta an update..Didnt get realy check anything out, as I'am job hunting. :sad:.But i let it warm up, drove 7 miles in to town.and at idle it there was still a haze of white kinda blue smoke.Is something getting worse?
Ezra
Postby Ezra » Wed Aug 27, 2008 7:40 pm
Ok,bumped my timing today.about 1/8th.Took it for a drive felt realy good.Got home went to shut the truck off,and it got realy quite but didnt shut off.Popped the hood and seen fuel leaking from the banjo housing to the left of the fuel filter.both washers are shot on the large banjo bolt and the little screw that goes in side the larger one, all the threads are gone.And when I pushed the throttle it looked like a white cloud machine.So I ended up having to stick a board over the turbo.So would the fuel leaking cause it not to shut off?
Ezra
Postby Okie Smokie » Thu Aug 28, 2008 4:51 am
It shouldn't. Sounds like your fuel shutoff solenoid on the back of your pump is not working properly. Make sure both wires are still hooked up. Did you get any king of warranty on the work or the pump when you had it installed? The washers you are talking about should have been replaced with new if the banjo bolt was removed, and if they stripped out the threads they should be responsible for that as well.
Okie Smokie
Postby sdstriper » Fri Aug 29, 2008 1:36 am
Wow... you need to step back and give that fuel system a real good once over... There are several rubber grommets in that fuel system as well as several banjo washers. The little thangs can getcha just like you discovered there with that banjo. And don't let the dude that installed the TPS backwords do anymore.
sdstriper
Fuel System "grommets", banjo washers etc
Postby sdstriper » Fri Aug 29, 2008 1:54 am
The rubber "grommets" as Cummins calls them and the banjo washers in the fuel delivery and fuel return systems. Someone please jump in if I have left anything out...
Cummins P/N , Cummins description, location & Qty
3909356 - rectangular ring, seal - square cut o-ring on the line nut @ the injectors (6)
3903380 - banjo connector, seal - 6.2 mm dbl banjo washers on injectors (6)
3918188 - sealing, washer - 8mm AFC banjo washers (2)
3905391 - grommet, seal - AFC tubing seal @ cyl. head (1) - fuel return line tee seals (3)
3905351 - grommet, seal - seals on fuel supply tube union from filter to VE (2)
3918191 - sealing, washer - 12mm banjo washer @ filter head and fuel supply tubing (2)
sdstriper
Postby Ezra » Fri Aug 29, 2008 8:26 am
Thanks sdstriper,Yeah he wont be doing anymore work on my truck.
Ezra
Postby Ezra » Fri Sep 05, 2008 11:50 am
Ok i got the fitting replaced.that stopped the leak.But know smoke is constantly coming out at idle blueish white smoke.so is that an air leak for sure?
Ezra
