Injector issues....snow balled into.....something else
Re: Injector issues
Postby ellis93 » Sun Nov 17, 2013 4:44 pm
dazedandconfused wrote:Mine would smoke like that Ellis when the timing was slipping.
See the last time this truck ran like this was when I pumped it full of crap fuel,and somehow the pump gear nut loosened. The key was boogered but from the view I got from my bore scope the gears keyway looked fine. Now..fast forward 1yr...I have this schit to deal with. I'll probably pull the front cover and take a look.
Re: Injector issues
Postby ellis93 » Mon Nov 18, 2013 1:40 pm
I haven't found a damn thing wrong :x
Least nothing horridly wrong,so far the IP gear was fine (key wasn't chewed) ,and the headgasket was still just leaking on the outside. This truck is torn all to pieces and I've yet to find the problem.......it has to be complicated,it's mine after all :x
Re: Injector issues
Postby ellis93 » Mon Nov 18, 2013 3:49 pm
I don't think there's anything wrong with the 230k bottom end
Looks to good in there
Freakin sad day for me
I ain't suppose to work on my truck,not in this much depth lol
What are you gonna do :lol: Damn thing better be glad I like it ;)
Re: Injector issues
Postby RCCUMMINS89 » Mon Nov 18, 2013 3:56 pm
Have you checked which injectors are messing up on the 7 holers?
Re: Injector issues
Postby ellis93 » Mon Nov 18, 2013 4:00 pm
They weren't.......it cleaned up with them,it acted like it was flooded down. Snapping,popping.....spitting back this morning. Acting really weird. I just said screw it I'm fixing everything wrong with it.
Re: Injector issues
Postby CumminsPower59 » Mon Nov 18, 2013 4:53 pm
I guess I never realized how small the IC piston bowls are...
Re: Injector issues
Postby RCCUMMINS89 » Mon Nov 18, 2013 5:09 pm
Starting to sound like a pump issue.....
But ya..........they are little tiny terds aren't they?
Re: Injector issues
Postby ellis93 » Mon Nov 18, 2013 5:37 pm
Eric idk......it could be but I'm gonna wait till the bitter end on changing it I reckon. I received a brand new old stock pump gear in the mail today so it's going on,then my head set should be here in the am along with the timing gasket and side cover gasket. I'm fixing everything else and saving the pump for last......I really wish I had somewhere close to test the pump but there isn't the first place that I feel won't screw me clos by. That is a sad fact all by itself,nothing but conartist and ripoffs around here.
I have this other thing I'm thinking on......I'm thinking of shimming my old valve springs to increase their tension to hold back my boost,rather than find some 60lbs'ers. Reckon there's anything bad or good to be realized from that
Re: Injector issues
Postby PToombs » Mon Nov 18, 2013 5:42 pm
I think you need to quit screwing around and pull the damn pump off and get it fixed! :roll: You're as bad as my buddy, he'll tear a whole truck apart trying to find a wiring problem and it's only a bad tail light! :lol:
Re: Injector issues
Postby ellis93 » Mon Nov 18, 2013 5:50 pm
PToombs wrote:I think you need to quit screwing around and pull the damn pump off and get it fixed! :roll: You're as bad as my buddy, he'll tear a whole truck apart trying to find a wiring problem and it's only a bad tail light! :lol:
Well Uncle Pete loan me 600$ and I will :lol:
Re: Injector issues
Postby PToombs » Mon Nov 18, 2013 6:01 pm
I would but I loaned my buddy $500 for his neck surgery. Doctor wouldn't operate with out a down payment and his insurance check comes tomorrow. The surgery is tomorrow too. ;)
Tear into it yourself, It can't be that hard, Ike took his apart 3 times at SOP. Of course, it still didn't run right and he put on a different one to drive home, but that could be installer error. ;)
Re: Injector issues
Postby RCCUMMINS89 » Mon Nov 18, 2013 6:14 pm
PToombs wrote:Tear into it yourself, It can't be that hard, Ike took his apart 3 times at SOP. Of course, it still didn't run right and he put on a different one to drive home, but that could be installer error.
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Re: Injector issues
Postby dazedandconfused » Mon Nov 18, 2013 6:14 pm
Hey Like finally got his running good though. Mine would do the same sthi Ellis. It would pop and smoke on startup. Once it ran a little it cleared up. I bumped the pump timing and that went away.
Re: Injector issues
Postby RCCUMMINS89 » Mon Nov 18, 2013 6:16 pm
Hey.....I went through my pump and it ran afterwards.... so it can't be hard...........took me like 14 hours though, mainly because I was looking for a spring for about 6 of them that our pumps don't have, but hey..... it still runs.
Re: Injector issues
Postby ellis93 » Mon Nov 18, 2013 6:32 pm
dazedandconfused wrote:Hey Like finally got his running good though. Mine would do the same sthi Ellis. It would pop and smoke on startup. Once it ran a little it cleared up. I bumped the pump timing and that went away.
That's just it Andy,I've got what would equal to a 3/16ths bump on it now,huh well not now. What I'm hoping for is to time it all out with the tools I've bought and try it,if it don't work out,I've another pump setting here. We will all know then ;)
I was just playing Mr Pete huh I mean Uncle Pete :lol:
