Dodge Down,screwed up symptoms
Re: Dodge Down,screwed up symptoms
Postby DodgeFreak » Thu Sep 06, 2012 10:09 am
mine sounded more of a chatter than a squeak, Not sure how to explain it other than a really fast chatter...lol Can you take a vid of yours popping off???
Postby ellis93 » Thu Sep 06, 2012 11:07 am
I can but I can't seem to upload them from phone,idk :?
The ones that didn't mist and just sprayed,I took them apart and looked inside,I didn't see anything at all. Put the back together and are spraying like the others now. Pressure is still off but I've ordered shims to fix them with 8)
Postby KTA » Fri Sep 07, 2012 7:59 am
The injector in that video was bad. This video is a good injector.
http://www.youtube.com/watch?v=X97tNy5q ... re=related
Postby ellis93 » Mon Sep 10, 2012 4:32 pm
Apparently theres issues in side the pump
I knew there was a noise I heard around that pump.
Postby PToombs » Mon Sep 10, 2012 5:13 pm
Looks like the gear was a little loosy!
Postby ellis93 » Mon Sep 10, 2012 5:35 pm
I really don't see how, I had loctite on the nut and it was torqued in place with the lock washer mashed :|
Could water caused this,maybe a hydrolock thing inside the pump :scratch:
Postby Exekiel » Tue Sep 11, 2012 7:03 am
Wow that looks chewed on, was the nut and lock washer new at the time it was installed? My local builder gave Me one with the pump when I had it inspected saying an old nut and washer could back off.
I would expect other type of damage from watter but I guess it could lock the shaft, still I would expect much more damage inside the IP.
1993 f350 with a 5.9l ctd and getrag
Exekiel
Postby ellis93 » Tue Sep 11, 2012 8:08 am
IDK, the nut and washer was old and was put back on after 366 install. I put the red loctite on it last time,this time I done the same plus I staked it after.Beooch better stay put this time :yuck:
Pumps back on,the injectors are set and back in, the truck runs once again but with a shake at idle. Not bad,just a touch that wasn't there before. I'm gonna run it a week and see what happens :bom:
Postby ellis93 » Wed Sep 12, 2012 5:42 am
Made a short run last night and the back to the shop this morning,127 miles and still runs good :wrench:
Postby dazedandconfused » Wed Sep 12, 2012 5:57 am
That's good to here.
