Not fueling like it did
Postby JustinRhodes » Sat Nov 12, 2011 5:29 pm
truck used to smoke like a freight train with the turbo spooled, now it only smokes with turbo not spooled. ive replaced fuel filter, checked fuel psi like 20 at idle and lowest ive got it to drop raw doggin it is 10 psi. ive cracked each of the injector lines and rpms drop like they should, took afc top off and the fuel pin is moving like it should. Any suggestions of what to look for now?
JustinRhodes
Re: Not fueling like it did
Postby AHineman » Sat Nov 12, 2011 7:39 pm
Did you fix any boost leaks? Does it have less power or just less smoke?
Postby JustinRhodes » Sat Nov 12, 2011 7:56 pm
AHineman wrote:Did you fix any boost leaks? Does it have less power or just less smoke?
I did not fix any boost leaks. less power and less smoke
JustinRhodes
Postby AHineman » Sat Nov 12, 2011 9:01 pm
You still getting full throttle travel?
Postby JustinRhodes » Sat Nov 12, 2011 9:20 pm
AHineman wrote:You still getting full throttle travel?
I'm pretty sure. I'll check tomorrow just to double check
JustinRhodes
Postby Tsbourne09 » Sun Nov 13, 2011 5:48 am
Street hood stack?
Not On Yet: 60#VS
Tsbourne09
Postby JustinRhodes » Sun Nov 13, 2011 7:39 am
Tsbourne09 wrote:Street hood stack?
Yep
JustinRhodes
Postby JustinRhodes » Sun Nov 13, 2011 11:12 am
Still getting full thorttle travel :(
Also just broke my banjo bolt that goes into the afc top, broke it off when i was threading it in by hand :lol:
I think i seen on levi's truck some air line stuff. So i might try to head up to sfs tomorrow and get my afc leak fixed. not that it matters tho, smoke screw is bottomed already :lol:
Im beginning to wonder if maybe its a injector issue. Im only getting like 17 mpg highway babying it (estimated, odometer broke)
JustinRhodes
Postby Tsbourne09 » Sun Nov 13, 2011 1:56 pm
Well i have seen mine as low as 14 before! But that was before the newness of the dennyt pump top and bottoned fuel screw wore off. Now its controlable. Could easily get 22ish.
Are they stock injectors?
Not On Yet: 60#VS
Tsbourne09
Postby JustinRhodes » Sun Nov 13, 2011 2:09 pm
Tsbourne09 wrote:Well i have seen mine as low as 14 before! But that was before the newness of the dennyt pump top and bottoned fuel screw wore off. Now its controlable. Could easily get 22ish.
I think they are.
JustinRhodes
Postby oldestof11 » Mon Nov 14, 2011 4:24 am
Bottomed or not, the pin still has travel. Fix the leak buy drilling and tapping the AFC top with a 1/8" NPT thread tap, get some nylon line and harware from ACE. I spent around 15 for everything. I lost about 7-10psi when mine broke. I bottomed out the smoke crew but could only get 27psi maybe. Now I can peg the 30lbs gauge and slip the clutch.
Postby JustinRhodes » Mon Nov 14, 2011 5:28 am
oldestof11 wrote:Bottomed or not, the pin still has travel. Fix the leak buy drilling and tapping the AFC top with a 1/8" NPT thread tap, get some nylon line and harware from ACE. I spent around 15 for everything. I lost about 7-10psi when mine broke. I bottomed out the smoke crew but could only get 27psi maybe. Now I can peg the 30lbs gauge and slip the clutch.
I only lost like 2 psi at full throttle. it sucks the most when going up a hill, and all the boost goes out the hole :lol:
And i talked to tacoclaw and he has the air line stuff in his truck, so im gonna go tonight hopefully to get that stuff.
JustinRhodes
