Turbo Upgrade
Turbo Upgrade
Postby nolafishr » Thu Jan 19, 2012 2:48 pm
I was reading where you can install a Turbo from a 04-07 model on to a 1st gen 12 valve engine. I was thinking of upgrading my turbo housing but after reading this it got me thinking, I have a turbo, intercooler/tubing and boots from a 2006 model and they are still like new with only about 12000 miles on the truck when removed. Can I install this on my 93 model? What would have to be modified to do this? Any info would be appreciated.
nolafishr
Re: Turbo Upgrade
Postby jacobwebb57 » Thu Jan 19, 2012 3:17 pm
i may be wrong but the turbo should bolt to the manifold you will have to move the exhaust back and fit the intercooler in, and get a third gen air horn..i think
91.5 4x4 5 speed, dennyt stage 2. ddp 50 horse injectors. glow shift boost, fuel pressure, egt, autometer tach, 60lb vavle spring, 3800 gov springs, 1 ton axles, custom intake, 4'' exaust, hx35w pump turned up 3 turns raptor pump, and 1/8 timing.. new injectors sooner or later
jacobwebb57
Re: Turbo Upgrade
Postby nolafishr » Thu Jan 19, 2012 4:02 pm
I did not think it would take too much to make this work, I also have the air horn from the other truck. I will wait and see what others will have to say on this. The Intercooler and Tubes should all be 3"so that will help improve air flow.
nolafishr
Re: Turbo Upgrade
Postby oldestof11 » Thu Jan 19, 2012 4:05 pm
If I remember correctly, you need to remove a pin to clock the compressor housing correctly. Beyhond that, the 3rd Gen cooler is huge! You need to cut the frame rails to get it to fit.
Re: Turbo Upgrade
Postby BILTIT » Thu Jan 19, 2012 4:15 pm
I just installed a turbo from an 06 (he351cw), powerstroke intercooler, and coolertubz IC piping.
3rd gen IC will not work, too much hassle, turbo works fine with some minor adjustments/fabbing.
IC piping:
See the very bottom, PS edition.
http://www.coolertubz.com/1991_-_1993_CoolerTubz.html
Turbo install here:
http://www.dieseltruckresource.com/dev/ ... 293p5.html
Derek B.
BILTIT
Re: Turbo Upgrade
Postby nolafishr » Fri Jan 20, 2012 3:53 am
Thanks for the info, I was not sure how things would fit, I remember reading about it. I tried the link on the Turbo swap but it wwas wrong, is there another one on here that shows you how to do this. I will have to check into the Intercooler also.
nolafishr
Re: Turbo Upgrade
Postby BILTIT » Fri Jan 20, 2012 6:57 am
Link for turbo swap is right, i just have alot of other upgrades going on aswell. If you read from that page on you will see the start and end of the turbo install, among the other installs i am doing.
Derek B.
BILTIT
Re: Turbo Upgrade
Postby nolafishr » Fri Jan 20, 2012 8:21 am
Thanks for the info, I did not read far enough into it that is why.
nolafishr
Re: Turbo Upgrade
Postby nolafishr » Fri Jan 20, 2012 10:20 am
Can someone give me more info on clocking the turbo, I understand it is rotating the housing, it is just that I have never done it before. I have changed out a turbo and manifold before.
nolafishr
Re: Turbo Upgrade
Postby CumminsPower59 » Fri Jan 20, 2012 10:42 am
It can be as easy as loosening up the clamp that goes around the housings, and rotating them to your liking, but since there are locating pins holding them in, take one side off completeley, remove the pin, and put it back together. Then do the other side. Not too terribly difficult, I did the same when I had my HE351ve apart ;)
Last edited by CumminsPower59 on Fri Jan 20, 2012 3:21 pm, edited 1 time in total.
Re: Turbo Upgrade
Postby BILTIT » Fri Jan 20, 2012 10:58 am
Take the pins out before mounting the turbo! The compressor housing has a large snap ring which is a bugger to install/remove while mountied on the truck. There are pins betweeen the comp. housing and centre body as well as the centre body and exh. housing. Both sides need to be removed so the centre body can be rotated to allow the oil inlet/outlet to be vertical.
One other thing is the manifold studs need to be backed out to be long enough so the nuts have enough thread to grab. The top two studs on the turbo housing need to be removed and the holes opened up so the existing manifold studs can be used.
Seems complicated but its not once you have it and can test mount it.
Derek B.
BILTIT
Re: Turbo Upgrade
Postby nolafishr » Fri Jan 20, 2012 1:14 pm
Thanks for the info, does not sound too bad, I will keep this in mind.
nolafishr
Re: Turbo Upgrade
Postby nolafishr » Sat Jan 21, 2012 3:56 am
I have a question about the oil line being vertical, on the 93 model it is located on the top of the turbo and on the 06 model turbo it is located on the bottom of the turbo for better draining to return to the engine. Does it matter where it is located? It seems that it is better on the bottom for better draining to return to the engine. I wanted to ask this because I noticed this.
nolafishr
Re: Turbo Upgrade
Postby BILTIT » Sat Jan 21, 2012 9:35 am
See my above post about removing pins. You need to pull them so you can move the body to make the oil ports vertical like the stock turbo is. Feed is in the top and drains out the bottom, vertical is best.
Derek B.
BILTIT
Re: Turbo Upgrade
Postby nolafishr » Sat Jan 21, 2012 3:02 pm
OK Thanks, I was wondering about this.
nolafishr
