Fuel pin is not doing much control of fuel
Postby 76 fummins » Wed Mar 06, 2013 10:26 pm
I have no boost running to the injection pump right now to try and clean up the smoke that didn't work. So I took the fuel pin out and replaced it will an 8mm deep socket relatively the same size as the fuel pin. I don't have an aftermarket pin to turn around. anyway no diff. still smokes like crazy. So Im not sure if the guide rod is stuck or what. I figured stuck in would be the opposite no smoke or boost. I have 3200 spring pump turned up and 6x16s.
76 F-100 cummins swap 6x16s, aurora 3000 with two hx 35s, 3200 gov spring, fass fuel, getrag, 35s, and 3.55 gears
76 fummins
Re: Fuel pin is not doing much control of fuel
Postby skilletky » Thu Mar 07, 2013 7:29 am
with the pump turned up and 6x16's, its going to smoke when ya get on the skinny pedal, but not have much top end go, unless the former owner of the truck did away with the afc lever inside the pump. i had 7x15's in my truck last year, and it would smoke doing the same thing with the socket in place of the fuel pin. can you tell a difference in the way it runs with the boost line hooked up and with it not hooked up?
skilletky
Postby RCCUMMINS89 » Thu Mar 07, 2013 7:55 am
It's because you have such a large injector. When I disable my afc, like you did... I can still get over 20# of boost. Some can still get 40, that just depends on how big of an injector you have.
Postby 76 fummins » Thu Mar 07, 2013 8:24 am
I have an air solenoid on a switch that i have flipped back and for no difference that i can tell. It will run 55psi either way. Controlling the fuel with the skinny is kind of a pain with 35s and 3.55 gears but if thats how it has to be with these injectors i can live with it. Is an auto any easyier to control the smoke.
76 fummins
Postby RCCUMMINS89 » Thu Mar 07, 2013 8:38 am
Did someone take out your afc lever at some point?
Postby 76 fummins » Thu Mar 07, 2013 9:59 am
Shouldnt be. Its just a reman pump i bought after my first one went bad
76 fummins
Postby skilletky » Thu Mar 07, 2013 10:26 am
just because it is a "reman" doesnt mean its always good. the "new guy" could have put it together. ive found this out several times.
skilletky
Postby RCCUMMINS89 » Thu Mar 07, 2013 10:47 am
If your fueling doesn't change with anything you do with the fuel pin, inclduing blocking it off like you said.
Pretty much the only thing that could be is the afc lever is missing.
Is there something I am missing?
Postby 76 fummins » Thu Mar 07, 2013 10:54 am
So wat u guys suggest. I thought it use to work when i had my stock injectors in it
76 fummins
Postby PToombs » Thu Mar 07, 2013 6:13 pm
Maybe your turbo isn't big enough for those injectors? Fill out your sig so we know what you are working with.
Postby 76 fummins » Thu Mar 07, 2013 6:57 pm
Havent figure out how to do that yet haha its an aurora 3000 with two hx 35s feeding into it once the turbos come up hardly any smoke at all.
76 fummins
