Centrifuging engine oil
Postby 1992gen1_fan » Thu Mar 20, 2014 6:31 pm
I was thinking about buying a bench oil centrifuge to clean soot out of oil. My trucks oil is black within a couple hundred miles after an oil change. Been that way since I bought the truck. Would draining the oil every thousand miles or so and running it through the centrifuge and dumping it back in hurt anything providing I did a clean job of it?
1992gen1_fan
Re: Centrifuging engine oil
Postby comotionman » Fri Mar 21, 2014 10:07 am
A centrifuge would be very helpful. I would install an onboard unit.
http://www.dieselcraft.com/engine-oil-c ... yxwbaNZ4ss
coupla trucks non & ic, 2nd gens, various other
comotionman
Postby 1992gen1_fan » Fri Mar 21, 2014 3:13 pm
I've seen those onboard units. That would be nice but I was thinking I could use a bench unit for other engines like my tractor ect.
1992gen1_fan
Postby Diesel » Fri Mar 28, 2014 2:57 pm
Is there any chance that you could remove something vital from the oil? How could the centrifuge know to remove only carbon solids but not other smaller and invisible to the eye ones?
1991.5 D250 Intercooled A518
Diesel
Postby 1992gen1_fan » Mon Mar 31, 2014 6:30 pm
Exactly what I'm wondering. If it was about the same rpm as the onboard units I assume it would be ok??
1992gen1_fan
Postby meby » Tue Apr 01, 2014 7:19 am
I don't know specifics, but a friend of mine just bought a centrifuge and it not only will strip out metals, it will strip out all additives as well.
edit: oh, he plans to burn the waste oil in his truck as fuel.
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby Diesel » Tue Apr 01, 2014 10:53 am
meby wrote:I don't know specifics, but a friend of mine just bought a centrifuge and it not only will strip out metals, it will strip out all additives as well.
I think you're right - I'm guessing dump it back in means the tank....in that case I would run it through a couple t-shirts and goooo :mrgreen:
Diesel
Postby 1992gen1_fan » Tue Apr 01, 2014 3:55 pm
Ok, thats what I was wondering. Maybe just better off pumping it through a few very fine filters instead. Or get an onboard unit that does'nt rob the additives. Thanks for the input.
1992gen1_fan
Postby 1992gen1_fan » Mon Apr 07, 2014 10:28 am
I just got an idea.. I have an old milk/cream sepperator That I was thinking to use for a centrifuge, ever heared of using one with oil? Might work for WMO. If I figured it correct, turning the handle one revolution per second spins the cone 10,800 rpm. :o Its like 180:1 ratio.
1992gen1_fan
Postby opiebennett » Tue Apr 08, 2014 3:56 pm
What are you trying to gain? Re-using oil can't be cost effective given what's at stake with the oiling system...
Bryan 'Opie' Bennett
91.5 5.9L with 21mm H1C/A518/NP205 Reg Cab LE Pyro/Boost/Trans Temp/BD Fuel Pin/Some fuel screw/Diamond Eye 4" exhaust/B+M Deep Trans Pan/3rd Gen aluminum wheels
opiebennett
Postby 1992gen1_fan » Fri Apr 11, 2014 7:46 pm
Soot and particle removal. I know soot in the oil is expected on an old worn engine but would be nice to keep the oil somewhat clean through the duration of its change interval. I eventually might just add a couple more filters to a bypass setup would probably be safer sounds like. The last time I did an oil test oil test, the additives were still good but there was alot of soot. I'm going to send a sample to test the oil at the current mileage and see how it looks.
As for the milk separator idea, I was thinking of using it for WMO as a fuel in an old diesel tractor ect. not re-use in the crank case ;)
1992gen1_fan
Postby comotionman » Sat Apr 12, 2014 2:16 am
http://science.howstuffworks.com/enviro ... eaning.htm
I believe centrifuge oil cleaning to be a proven method providing longevity to expensive engines used in transportation, construction and heavy industry. While I have not read a lot about it, I do not believe it will strip out needed additives. When properly used its well established to be effective. If you find evidence contradicting please point it out.
comotionman
Postby comotionman » Sat Apr 12, 2014 2:45 am
Deleted accidental double post
comotionman
