BIG C wrote:My trucks build date is 12/ 1991.
I saw the TINY TACH website and there tach gets a reading from the injector line by using a transducer to read the 'pulses'.
does anyone know how accurate these are?
ford69557ci wrote:i have a sensor setup from dakota digital that convets the teeth on your flywheel to a reluctor ring. i run and auto metet pro comp memory tach with it and have had no trouble its just a slight paint to set it all up but once its done its done
shoot4fun wrote:my '92 Ex-cab has a tach wire under the dash. Dodge didn't use them because the tach was so jumpy until the engine warms up, engineers were worried people would complain...
