TACHOMETERS
TACHOMETERS
Postby BIG C » Wed Jan 16, 2008 7:56 pm
Does anyone have any insight on tachs for my 92 dodge 5.9ctd?
I have had a auto meter in it. it's a 2888 model I think or similar.
It has failed. I would like to put one in that does NOT get signal from the alternator. Also it doesn't need to be 5" in diameter.
BUILT 12/1991
DODGE W250, CLUB CAB, 5.9 CTD, INTERCOOLED, NEWLY REBUILT AUTO TRANS, 4X4, 190,000 MILES, NO MODS YET.
BIG C
Postby cummins king » Wed Jan 16, 2008 10:22 pm
as far as i know thats the only way to get a reading for deisel
93 4X4 auto
cummins king
Postby Bookshelf » Thu Jan 17, 2008 5:48 am
if yours is a 92 it should be able to use the isspro tach which uses the factory wiring and (I assume) gets its reading from the factory crank sensor. You could use a factory tach too if you can find one.
91.0 W250 Auto
90 Chevy V30
Bookshelf
Postby BIG C » Thu Jan 17, 2008 6:07 am
My trucks build date is 12/ 1991.
I saw the TINY TACH website and there tach gets a reading from the injector line by using a transducer to read the 'pulses'.
does anyone know how accurate these are?
BUILT 12/1991
BIG C
Postby gomerpile » Thu Jan 17, 2008 6:37 am
well i went the cheap route and bought a cheap gasser tach, mine is a sunpro super tach II, just set it on 4 cyl and your good to go, except when its cold in the cab, but once the tach warms up it reads really accurite, also you just tap into the exsisting harness under the dash.
1992 Dodge D-250 LE auto, LSD w/3.54, about 200,000+ miles.Isspro Pyrometer , Sunpro tach,Tractor Supply Boost Gauge, Old Smokey Fuel Pin,4 turns on fun srew, starwheel turn CCW 1 turn, 40hp injectors, BHAF,16 cm housing.Sony Head Unit.
gomerpile
Postby seeker1056 » Thu Jan 17, 2008 7:35 am
I use a tach called "Tiny Tach"
Digital to 10,000 rpm and has hour meter etc in it
Costs about $80.
Best part is it clamps to an injection line to read the pulses and two wire hookup for power
Only downside is no internal illumination for night driving
Sponsors of new truck
Performance Diesel Injection
Colt Cams
H&H Offroad
Arties Transmission
Toms Contracting
seeker1056
Postby burnt_servo » Thu Jan 17, 2008 8:30 am
BIG C wrote:My trucks build date is 12/ 1991.
i have a timing module made by snapon that does the same thing ... it is very acurate in it's reading of the injection "pulse " ...
figuring out when the fuel actually decides to burn is another matter .
burnt_servo
R8912
Postby Ace » Thu Jan 17, 2008 4:32 pm
I got a crank sensor kit from egauges.com for like $50 at the time, IIRC. Part R8912. Has a couple magnets you glue to the crank damper and a sensor bolted on with an oil pan bolt.
Wired up an ISSPRO 2 1/16 tach I found on eBay with it. Been rock solid and trouble-free for going on 2 years now.
Postby cummins king » Thu Jan 17, 2008 4:43 pm
well now i know of alot more ways of doing it :lol:
93 4X4 auto
cummins king
Postby ford69557ci » Thu Jan 17, 2008 6:01 pm
i have a sensor setup from dakota digital that convets the teeth on your flywheel to a reluctor ring. i run and auto metet pro comp memory tach with it and have had no trouble its just a slight paint to set it all up but once its done its done
ford69557ci
Postby Bookshelf » Fri Jan 18, 2008 8:34 am
ford69557ci wrote:i have a sensor setup from dakota digital that convets the teeth on your flywheel to a reluctor ring. i run and auto metet pro comp memory tach with it and have had no trouble its just a slight paint to set it all up but once its done its done
How much was that setup from Dakota Digital?
91.0 W250 Auto
90 Chevy V30
Bookshelf
Postby ford69557ci » Sun Jan 20, 2008 4:42 pm
i got mine for 100 bucks on ebay but they are listed anywhere between 90 and 130 bucks
ford69557ci
Postby shoot4fun » Tue Feb 12, 2008 2:42 pm
my '92 Ex-cab has a tach wire under the dash. Dodge didn't use them because the tach was so jumpy until the engine warms up, engineers were worried people would complain...
'92 D250 4WD, Bone Stock except for the '78 Ford Crew Cab body that's getting ready to land on it...
shoot4fun
Postby Bookshelf » Tue Feb 12, 2008 7:00 pm
shoot4fun wrote:my '92 Ex-cab has a tach wire under the dash. Dodge didn't use them because the tach was so jumpy until the engine warms up, engineers were worried people would complain...
I've had a few factory tach trucks and they've always been rock solid.
91.0 W250 Auto
90 Chevy V30
Bookshelf
Postby SChandler » Tue Feb 12, 2008 9:07 pm
I run the Isspro with with their wiring harness. If yours is a 92 it should have the factory plug under the dash for the wiring. Super easy to do and the tach movement is smooth and consistent, never noticed any jumpiness.
SChandler
