so hooked up the pyro and boost gages today
Postby grumpy » Tue Sep 16, 2008 12:31 pm
and I'm reading between 7,8 on the pyro and max boost of 15..so the question I have is how do I get more boost?? fuel screw or something else.I have snoot's old turbo a HX-35/40 hybred..
thank's for all the input in advance..
grumpy
93 dodge w350 excab daully auto 3600 gov spring 4" streight pipe,hx-35/40 turbo
91 jeep xj trail rig I-6 5spd exo cage 7inch lift
87 35ft gooseneck trailer soon to have 79camper on it.
grumpy
Postby fourwheelininajeep » Tue Sep 16, 2008 3:21 pm
Hey grumpy
Yah you got to turn that thing up, are you looking for crazy power for racing or just good seat of the pants but still reliable and decent gas mileage. How you want to use it is what you got to tune it for
1990 dodge w350 cab and chassis frame single rear wheel 99000 miles with chrome stacks between cab and bed paid 1300 for it after a years worth of work i got to drive it
fourwheelininajeep
Postby grumpy » Tue Sep 16, 2008 5:04 pm
not looking to race just good seat in the pant's funtime...I'll be towing with this truck on and off...
grumpy
Postby fourwheelininajeep » Wed Sep 17, 2008 7:34 am
Here is what I did you get the best of both worlds, either grind your fuel pin or get an already ground one, then turn your screw up, not to much just enough that it will smoke decent at low end when you get after it. This way you can still get good cruising and good fuel mileage at low end but when you punch it and get some boost to the diaphram it will push that fuel pin down only after the turbo has thoroughly lit and then will dump some fuel down. Just watch your egts. Remeber though that the fuel screw has to be turned in atleast a couple before grinding the fuel pin will help at all. If the fuel screw is not turned in by design the ip will never allow the fuel pin to work correctly. I would start at 2 turns in and drive it a couple of times then pull your fuel pin back out and check your trail, make sure that the needle is riding on it for the whole travel. If it is putting in the fuel screw will dump more fuel at low end put probably wont give any more up on top. Let me know how it goes.
fourwheelininajeep
Postby grumpy » Wed Sep 17, 2008 9:20 am
will do thank's for the info
grumpy
Postby grumpy » Wed Sep 17, 2008 5:16 pm
so got the boost up to 25 today so I'm going to turn it up one more turn..
grumpy
Postby fourwheelininajeep » Wed Sep 17, 2008 8:03 pm
What kind of egts you running my dads truck is turned in 3 turns and had the fuel pin grinded by yours truly he gets about 32 psi on a good day and runs 1300. Is your truck intercooled or not. How far did you turn it in before you got 25. Im happy for you you have the bug now you just have about 15 more tweaks before you get exactly what you want until a week later then you will tweak it some more. Its an obsesion, dont you love it.
fourwheelininajeep
Postby grumpy » Wed Sep 17, 2008 8:32 pm
1000 max sofar..
grumpy
Postby Firstgenfanatic » Wed Sep 17, 2008 8:45 pm
Hey Grumpy,
do you have a modded fuel pin?
*1993 Dodge Ram W250 club cab*, mild performance built A518, Hughes Converter, turned-up VE w/timing bump, tow package, 16x7 Alcoa wheels, M&H "M5" fuel pin, 366 gov spring, 4" exhaust, 16cm turbine housing, cold air intake, Isspro pyro/trans/tach/boost, KDP secured
Firstgenfanatic
Postby grumpy » Thu Sep 18, 2008 12:16 am
Firstgenfanatic wrote:Hey Grumpy,
nope not yet don't have the $$ for that yet just doing the thing's on the cheap for now..
grumpy
Postby fourwheelininajeep » Thu Sep 18, 2008 8:16 am
Hey get back on the search in this forum and look up the old smokey fuel pin, it shows you how to take out your fuel pin and grind it to get the same affect as if you put a bully dog, this way you can custom tune your fuel curve. Everybody says they dont want to because if they dont like it and want to go back to stock they cant. If you just take the pin out and rotate it 180 degrees you will right back at stock. But I guaruntee you wont do that. Cost to do this mod. $0 Check it out its well worth your time I have done it to my dads, it made a huge difference that is where you need the fuel at the top in when the turbo lights.
fourwheelininajeep
Postby grumpy » Thu Sep 18, 2008 9:26 am
fourwheelininajeep wrote:Hey get back on the search in this forum and look up the old smokey fuel pin, it shows you how to take out your fuel pin and grind it to get the same affect as if you put a bully dog, this way you can custom tune your fuel curve. Everybody says they dont want to because if they dont like it and want to go back to stock they cant. If you just take the pin out and rotate it 180 degrees you will right back at stock. But I guaruntee you wont do that. Cost to do this mod. $0 Check it out its well worth your time I have done it to my dads, it made a huge difference that is where you need the fuel at the top in when the turbo lights.
snoot already did this when we put the 3200 gov spring in...
grumpy
