and I'm reading between 7,8 on the pyro and max boost of 15..so the question I have is how do I get more boost?? fuel screw or something else.I have snoot's old turbo a HX-35/40 hybred..
thank's for all the input in advance..
grumpy
Firstgenfanatic wrote:Hey Grumpy,
do you have a modded fuel pin?
fourwheelininajeep wrote:Hey get back on the search in this forum and look up the old smokey fuel pin, it shows you how to take out your fuel pin and grind it to get the same affect as if you put a bully dog, this way you can custom tune your fuel curve. Everybody says they dont want to because if they dont like it and want to go back to stock they cant. If you just take the pin out and rotate it 180 degrees you will right back at stock. But I guaruntee you wont do that. Cost to do this mod. $0 Check it out its well worth your time I have done it to my dads, it made a huge difference that is where you need the fuel at the top in when the turbo lights.
