air compressor vacuum
Postby grumpy365 » Thu Jan 28, 2010 10:45 pm
I have a Haldex/Midland air compressor and I am teying to figure out how to use this as my vacuum pump as well as on board air. :?
I will also need to mount some kind of power steering pump behind my compressor.
If anyone has done this, or knows how to go about it I would apprecaiate thier input.
THANKS
grumpy365
Postby PToombs » Fri Jan 29, 2010 6:01 pm
Most of the compressors used on the 5.9's in industrial stuff had the capability to mount something on the back, like the PS pump.
If you send a PM to jensenkennels I'm pretty sure he used a compressor like that on his monster he's building.
I don't think you can use it for both air and vacuum though, it needs flow to build air pressure, and for vacuum it needs to draw from a closed system.
Postby grumpy365 » Fri Jan 29, 2010 8:42 pm
I FINALY GOT IT, jensenkennels is using the Vanco Hydroboost to do away with the need for vacuum. (I am a dumbass for not seeing it sooner)
grumpy365
Postby Begle1 » Fri Jan 29, 2010 10:51 pm
I would think that there would be some way to use a relief valve to have the compressor draw so much vacuum, and then draw outside air after that?
If you're using hydroboost, then I would just use a little 12 volt pump for the HVAC doors and valve. Is there anything else vacuum powered?
Think a compressor could work as a crankcase scavanger?
Postby PToombs » Sat Jan 30, 2010 7:43 am
It could, but do you want to suck all that oil fumes thru your compressor?
Grumpy, that's right, I forgot how he did it. :oops: I need to go over and see what progress he's made. It's an awesome truck. 8)
