IowaCummins wrote:A special thing the VE pump has. if you look on the pump there will be a solenoid about 4"s long and has a small 1/16" hard tube comming out the bottom. for cold weather starts it takes a reading from its sensor on the intake manifold and if cold enough it will supply power to the solenoid to advace the timing 7 degrees. this 7 degrees helps the engine start ane run better. people also run a straight 12v source to this solenoid which is called "hot wireing the KSB" so its advaced 7 all the time.
Richie O wrote:IowaCummins wrote:A special thing the VE pump has. if you look on the pump there will be a solenoid about 4"s long and has a small 1/16" hard tube comming out the bottom. for cold weather starts it takes a reading from its sensor on the intake manifold and if cold enough it will supply power to the solenoid to advace the timing 7 degrees. this 7 degrees helps the engine start ane run better. people also run a straight 12v source to this solenoid which is called "hot wireing the KSB" so its advaced 7 all the time.
The non coooled trucks are powered all the time for correct timing and the cooled trucks are activated by power. The non cooled trucks have a slow acting wax filled actuator and can not really be controled by adding or taking away power. ( its not an instant thing ) You also do not want to run the pump with the KSB advanced all the time. It increases case fuel pressure and will cause added wear and heat on the pump. Most guys that have a factory cooled truck just use the hot wired or switched ksb for quick racing or dyno runs.
