2015 BS and Chat Thread!
Re: 2015 BS and Chat Thread!
Postby DodgeFreak » Thu Feb 05, 2015 3:39 pm
The more I look at this the more depressed I get lol.
Postby PToombs » Thu Feb 05, 2015 5:51 pm
Don't look! :lol:
Postby meby » Thu Feb 05, 2015 5:54 pm
Can someone explain why the new 1500 trucks have better weight ratings than the old 2500 trucks? Am I missing something?
-1991 D-250 bone stock
-1997 Civic Hatchback
-Case 530 CK
-Speedex Walking Tractor.
-BCS Walking Tractor
www.ebyfarmsllc.com
meby
Postby ellis93 » Thu Feb 05, 2015 6:16 pm
PToombs wrote:Don't look! :lol:
I think duct tape comes in the shade of blue as well :lol:
Postby DMan1198 » Thu Feb 05, 2015 6:30 pm
meby wrote:Can someone explain why the new 1500 trucks have better weight ratings than the old 2500 trucks? Am I missing something?
New frame. New rating method being used
Postby DMan1198 » Fri Feb 06, 2015 7:34 pm
http://www.cumminsforum.com/forum/3rd-g ... st17147114
A vague question turned into so funny answers
Postby RCCUMMINS89 » Fri Feb 06, 2015 7:39 pm
8)
Postby DMan1198 » Fri Feb 06, 2015 8:24 pm
Now for some reason cumminsforum isn't loading
Postby DMan1198 » Fri Feb 06, 2015 8:40 pm
Ok it's working again. Crisis averted
Postby txs » Sun Feb 08, 2015 2:11 pm
twice now I've had to tow the 93 to start it, it can sit several hours and start right up but after a few days no smoke, no run, turns over just fine. I'm thinking it's gotta be seeping air into the pump or injection lines somewhere. Starts right up within a hundred foot when towed with it in third gear.
txs
Postby Remps » Mon Feb 09, 2015 10:32 am
Maybe pressurize the fuel tank to 10-20 psi and check for leaks, or put a check valve before the LP. On another note I bought myself a used ironman inversion table about a month ago for lower back issues. It does help some, usually only hang between 20 seconds to a little over a minute. The trick is to turn yourself upside down slowly to avoid a head rush. First time I did it I puked from doing it too quickly. I am glad I bought it, I use it almost every day.
Postby DodgeFreak » Mon Feb 09, 2015 11:52 am
I bought one. Once i got used to hanging upside down I would fall asleep for 15 or so minutes lol. I got bored hanging there.
Postby CumminsPower59 » Mon Feb 09, 2015 4:41 pm
Remps wrote:Maybe pressurize the fuel tank to 10-20 psi and check for leaks, or put a check valve before the LP. On another note I bought myself a used ironman inversion table about a month ago for lower back issues. It does help some, usually only hang between 20 seconds to a little over a minute. The trick is to turn yourself upside down slowly to avoid a head rush. First time I did it I puked from doing it too quickly. I am glad I bought it, I use it almost every day.
I'd go 10psi max. That's a lot of pressure on the tank.
Postby ellis93 » Mon Feb 09, 2015 5:46 pm
Might be Ike,think about the poundage it holds up full. I've personal had them looking like a balloon :lol:
Postby cmann250 » Mon Feb 09, 2015 6:52 pm
Joke of the day: $950 for 4 285-75-16 BFG ATs
What the heck happened to the tire market?
