2015 BS and Chat Thread!
Re: 2015 BS and Chat Thread!
Postby DMan1198 » Fri Feb 20, 2015 6:31 pm
So I get to pick up a 98 24v next week for $200. Then when I have the funds I'll also be getting a ve engine, and 47re, and a 6.4 cummins from the same guy
Postby ellis93 » Fri Feb 20, 2015 7:13 pm
cougar wrote:Can't say I'm overly impressed with my 24 valve. Doesn't seem to have any realistic advantage to me anyway over a 12 valve. Converting to a VE or P pump will eliminate the electrons problems and bring back that part of reliability, but also holds you back in power possibilities that only the electronic can give you. A 24 valve may have a slight advantage when it come to twins, but is it worth it? Now if only they would come up with a VE/VP hybrid. That would be interesting.
I like the 24v'ers. The idle noise and upper rpm sound is what I'm mostly after,then the oddity of the swap has its own allure. Power would almost have to be increased as well,compared to the same fueling in a 12v. There's just more room for air to travel in and out.
Postby cmann250 » Sat Feb 21, 2015 3:06 pm
Postby RumbleFish » Sat Feb 21, 2015 6:36 pm
I saw that today lol. I kinda wanna text him to see what truck norris actually looks like. It beyer be really nice for that money.
Postby RumbleFish » Mon Feb 23, 2015 6:06 am
Both my daughters and one of thier boyfriends work at pizza hut. So i get a call from him at work yesterday asking if i can go pull the delivery driver out of the ditch. Turns out it was directly across the field from my dads house. Driver slid thru a stop sign at a T-road and couldnt make it up the incline back onto the road. I pulled him out at an idle in first gear. And then got paid with free pizza. Score!
Postby DMan1198 » Mon Feb 23, 2015 6:30 am
Free pizza is always nice
Postby MMeier » Mon Feb 23, 2015 9:27 pm
DMan1198 wrote:Free pizza is always nice
Yes it is, now some free beer to wash down said free pizza... better yet !! :jumpsmile:
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
Postby DMan1198 » Tue Feb 24, 2015 10:30 am
Indeed. Pizza and beer is an excellent combination
Postby DMan1198 » Wed Feb 25, 2015 7:21 pm
So for clarification purposes (and because I have a rubbish memory sometimes) what's the fitting size on a ve fuel inlet? I want to make sure I order the right piece, so I can get The Roo Hunter back up and running (hopefully) with a new fuel system when I get home
Postby RCCUMMINS89 » Wed Feb 25, 2015 7:25 pm
Ya know.... that's something that ya think I would know..... but I don't.
Postby ellis93 » Wed Feb 25, 2015 7:47 pm
DMan1198 wrote:So for clarification purposes (and because I have a rubbish memory sometimes) what's the fitting size on a ve fuel inlet? I want to make sure I order the right piece, so I can get The Roo Hunter back up and running (hopefully) with a new fuel system when I get home
Best I can do is look in the 5gallon bucket o pump parts and see :lol:
Postby DMan1198 » Wed Feb 25, 2015 8:22 pm
I've seen it posted elsewhere before. It's a 1?mm X1.5, but I'm not sure if it's 10mm or 12mm
Postby ellis93 » Wed Feb 25, 2015 8:31 pm
Probably 12mm. That seems to be the cummins fittings flavor.
Postby DMan1198 » Wed Feb 25, 2015 8:42 pm
You're probably right. If I read it right the cp3's use that size for fuel inlet too
Postby DodgeFreak » Thu Feb 26, 2015 5:40 am
12mX1.5
